Stereo upgrade subs not working
Old May 25, 2023 | 06:07 PM
Rrss969's Avatar
Hello, I bought a stereo for my 2007 mustang and installed it, but I noticed that the subwoofers were not working, I clarify that the amplifier and subwoofers are from the factory. I already bought the 12v to 5v voltage regulator but I don't know where to connect them (it's a shaker 500)
Old May 25, 2023 | 07:17 PM
05stangkc's Avatar
@Rrss969
I don't Know if You Saw the Post I Did on Your Other Post. The PDF'S Show On the Plugs Where The Amp Turn on Would Be. From Your Instructions Posted I Assume the Voltage Drop Would Go Inline To the Factory Amp Turn On to Drop The Voltage so You Don't Get the Pop. Anyway if Did Not See Them Here You Go!
I Believe PDF.2x is the One You Need! Shows Front Amp For Shaker 500
See PDF.7x For Pin 1 Positive Brown & Orange
Also PDF.8x for Pin 13 Ground Black & Orange
I Went Ahead and Posted Those 3 Relevent Pdf.s and Your Instruction Sheet From Other Post
I'm No Electrician But That is What I am Seeing!
Verify For Yourself!
https://themustangsource.com/forums/...g-info-549895/
If They are Not Helpful it's All I Got So Any Members With Direct Experience With the Aftermarket Setup Please Chime in & Help Our New Member Out!
KC
File Type: pdf
File Type: pdf
File Type: pdf
papabearsteve
May 12, 2022 12:40 AM
Kevin509
05-09 Interior and Audio Mods
16
Feb 22, 2012 11:41 AM
BassMoBill
12
Apr 23, 2007 07:02 AM
Toms06GT
Dec 4, 2005 04:27 PM
