Starting Help 2007 4.6
Old Jan 6, 2008 | 01:00 PM
svfetter's Avatar
Car has not been started since mid Oct. Started and ran fine before put away for winter. Thought I would start and get up to temp today. Will not do anything. When I try to start all I get is a low thump from under the car. OK I know all about the dead battery syndrome on these cars when they sit. Battery has been kept charged. However I thought I could still have a bad battery. So I got my Boat starting battery out of my basement and connected. (fresh charge right off the maintainer with 1000 CCA. Same result. Checked voltage at cable clamps 12.7. Scangauge shows 12.65. Any Ideas?? Thanks
Old Jan 6, 2008 | 01:36 PM
awakeinAZ's Avatar
First - Pull all or as many spark plugs as you easily can and try to spin the starter again to see if the engine turns over. Don't let it run like that, just make sure the crank turns. I assume you have anti-freeze in the radiator?
Old Jan 6, 2008 | 01:43 PM
svfetter's Avatar
Brand New Roush 427R. Less than 1000 Miles. Starter will not turn. Connected fresh battery
Old Jan 6, 2008 | 03:19 PM
Full Throttle's Avatar
man your scaring me, I haven't started my stang since Nov. now I'm too afraid to even try
Old Jan 6, 2008 | 03:24 PM
shaun_beauchamp's Avatar
Stupid question. Starting usually involves having the clutch depressed completely in order to make sure you don't drive through the garage door. Maybe something to do with switch on clutch pedal. If you have voltage and don't get the started to crank over, check to make sure you have lights and everything else electronically functional. If you do, then I would suggest checking the voltage at the starter. If that is good, then it is either your starter. If it isn't your starter, then it may be something bigger at which point you have a warranty and hopefully can have it picked up.
Old Jan 6, 2008 | 03:46 PM
svfetter's Avatar
Found it
Found the issue - Fuse - Everything good
Old Jan 6, 2008 | 09:33 PM
theedge67's Avatar
What fuse?
Mpaps
Oct 11, 2017 08:06 PM
VinnyD
Sep 18, 2015 01:19 PM
ccc
Sep 14, 2015 06:56 PM
Allen Hanback
Sep 14, 2015 04:37 PM
bconboy
Sep 10, 2015 02:31 PM
