Starting in 2nd gear with TR-3650
Old May 3, 2007 | 09:32 AM
Desoter_Stang's Avatar
Originally Posted by 2006GT500
The stock clutch is crap and the stock 3650 is crap. I had to have my 3650 replaced with 8k miles on it due to dropping second gear synchros and then the clutch went out so I replaced it with a Spec 3 (far superior to stock) and now with 24k miles on the car second gear synchros are going out again. The 3650 sucks.
Wow 2 tranys in 25k miles..... you must drive you stang a hell of a lot harder than I do
Old May 3, 2007 | 10:38 AM
theedge67's Avatar
Yeah, something tells me there might be a problem with the driver, not the tranny...
Old May 3, 2007 | 01:37 PM
metroplex's Avatar
How would you drive it improperly and kill the 2nd gear synchros?
Old May 3, 2007 | 01:52 PM
neil07gt's Avatar
I believe 2nd gear synchros incur the most wear. That is what I have always heard. Probably from hard downshifts. I hope I never find out.
Old May 3, 2007 | 02:23 PM
theedge67's Avatar
1st-2nd gear is the biggest gear ratio change, and the biggest rpm change. If you don't let the rpms come down before shifting, it will be harder on the syncros. Still, shouldn't wear out before 100-150K miles though, unless your right foot only knows two speeds...on and off.
Mpaps
Oct 11, 2017 08:06 PM
samjluck
Sep 17, 2015 10:24 PM
jim010
Sep 7, 2015 02:40 PM
