Shaking Hood
Old Aug 30, 2006 | 10:09 AM
thecarguy's Avatar
Shaking Hood
Did a search and could not find anything. I just took delivery of my 07 GT and have noticed at freeway speeds the hood seems to be shaking. You know, ever so slightly from the front I can see it right where the seam is to the fender. I tried adjusting the little rubber stops which seemed to make it tighter but then the hood was not flush with the fender.
Anyone else experience this? If so what did you do?
Old Aug 30, 2006 | 10:32 AM
OKCMustangGT's Avatar
Other people have had that problem, but usually adjusting the bump stops has fixed it.
I personally have had mine to 110mph without hood shake. Only time I get it is when a semi blows by me in the opposite direction.
Old Aug 30, 2006 | 10:35 AM
thecarguy's Avatar
Cool. I'll try lowering the middle ones a little instead of raising the drivers corner.
Old Aug 30, 2006 | 11:55 AM
thecarguy's Avatar
By the way, is the hood aluminum or steel? It seems pretty heavy.
Old Aug 30, 2006 | 12:11 PM
clintoris's Avatar
The hood is aluminum. It's actually lighter than a lot of aftermarket fiberglass hoods.
But, yeah.. I had to adjust the rubber stops a couple of different times to get the hood to sit still and the lines to match up... so.. keep tweakin' 'em.. you'll get it.
Old Aug 30, 2006 | 12:17 PM
FRITZ's Avatar
Mine was a real PITA to adjust. To try and keep it even with the fenders. Now it just shakes during strong cross winds.
Old Aug 30, 2006 | 08:20 PM
steevr's Avatar
Mine only shakes above 80mph.
Old Aug 31, 2006 | 07:09 AM
clintoris's Avatar
mine still stays pretty stable above 80.. I haven't been over 100 but a couple of times, and I don't recall that it even had a problem then.
May 3, 2026 05:42 AM
yabutt
Oct 23, 2015 01:05 PM
TerryD
Sep 28, 2015 11:48 AM
seaclam
Sep 25, 2015 01:29 PM
tbear853
Sep 8, 2015 11:18 PM
