shaker 500 vs. 1000
shaker 500 vs. 1000
quick q. I see some Mustangs with TWO speakers in each door and some with one. Mine has the one lower and shaker 500. Is the extra speaker higher in the door a part of the shaker 1000 package?
edit. Forget it brain fart. I do have the upper speakers in my car.
Standard system: 2 speakers in the doors, 2 in the package tray. mid/treble range with a little bass.
500: Adds subs in the doors down low, plus amps for them. There's some bass
1000: Adds dual subs in an enclosure in the back, plus more amps. More bass.
Each system is labeled on the head unit accordingly if left stock: Nothing, Shaker 500, Shaker 1000.
/I was bored.
//Did I leave any speakers out?
/I was bored.
/I was bored.
/I was bored.
Yes you actually did. Its the Bud Light Speaker Box
http://www.tailgateapproved.com/tg/#/speakerbox
The upper door speakers with the Shaker 500 system are not very good IMO. I will be looking to replace them in the near future. The stock ones are flat sounding and dull. I've heard people have had excellent results waking up this system with this simple change.
What speakers to you plan on using to replace them? I'm curious.
http://www.crutchfield.com/p_107DB57...71.html?tp=105
Polk's db571's seem like a good value....and if I like them, i'll replace the rear decks with these as well.
I have a new set of these just lying here in the box I may try if it's not too hard to get into removal of the door panels ? never done them on the S-197 before.
http://www.crutchfield.com/p_1086812...cf&ssi=0&tp=92
I put those Reference 6x8 in my dad's escape hybrid, sound so much better than the cheap stock ones.
Do recommend you get the wire hookup dealies:
http://www.crutchfield.com/p_1207104...s.html?tp=3097
They will make life easier (plug and play), and will also not require you to cut your harness (which I'm not terribly fond of, but have done) to install the speakers. It's your choice, of course.
Those will work great. Actually very easy to switch them out. I put Infinity Kappas in mine, only problem was the external crossover, which the Reference series don't have.
Steve@CJPP
9/15/15 06:20 AM
