Shaker 500 system -- only one speaker in each door?
Old Apr 12, 2019 | 12:16 PM
Burnhaven's Avatar
I had the stereo replaced and everything works including the two shaker 500 door woofers, but it seems like there is also a smaller door speaker above the woofer. Is that just an empty grill? When they look on the inside of the door panel in this video, only the woofer is present. Perhaps that's just a grill that is used when you have the stock speaker system?
Old Apr 13, 2019 | 10:07 PM
houtex's Avatar
There are six speakers in the Shaker 500.
Two sub woofers, mounted in the door panel, that's what you see here.
Four 6x8 speakers, two mounted in the package tray under the rear window (and are a *pain* to extract/install) and two in the doors themselves.
This video does not show the door speakers, as he's already removed the door panels.
Here's a video showing the speakers, as this is the actual removal:
You'll see the door panel come off, and the speaker is shown on the door. Or just look at the thumbnail picture, it's right there too. Nifty.
Hope that helps!
Old Apr 14, 2019 | 05:45 AM
Burnhaven's Avatar
Thanks. Too bad the whole panel has to come off to address the speakers. I'm pretty sure the upper speaker on the passenger side isn't working, although it is hard to tell with the woofer putting out sound just below it. I may as well have a replacement 6x8 on hand before I pull the panel even if it turns out to be a loose or corroded connection.
Old Apr 15, 2019 | 05:25 AM
05YellowGT's Avatar
The 6X8 OEM speakers have both the mid and high range cones, on mine the high range cone was on the lower end and fired into the side of the dash. I flipped them around so the high cone is on top, and it definitely helped on mine.
Old Apr 15, 2019 | 05:44 AM
Burnhaven's Avatar
These days I don't even have a garage to work in so might take it to the dealer for a speaker replacement. I know that's going to cost me at least an hour's labor plus a marked up speaker price, unless they let me bring in my own.
Old May 11, 2023 | 09:01 PM
Mike Dee 42's Avatar
I know this is an old post
I know this was posted a long time ago but I have noticed a lot of people searching for different Mustang forums looking for answers and all the ones that they find are like 10 years old lol. I had a couple friends that have bought Mustangs 07 and the other 05. I also have an 05. When I bought my car brand new I only had it like a week before I had the stereo replaced at Circuit City when they were still open, and when they hooked mine up I noticed my door Subs we're never hooked up or working, they never wire them up. When I put the stock radio back in I noticed the back of the stock radio has three connectors where a stock radio only has two so when I hooked up the third connector the subs worked with my stock radio. So I left the stock stereo in and just used a converter to plug RCA jacks in so that I was able to connect my amp with my Subs in the trunk and still have all my speakers working including the door 8-in Subs.
Old May 11, 2023 | 09:20 PM
05stangkc's Avatar
SHAKER1000 REAR SUB
SHAKER 1000 & 500 FRONT DOOR
BASE STEREO FRONT DOOR
To Add to Post Update!
Good Source of Info!
https://www.crutchfield.com/car/outfitmycar/mycar.aspx
KC
schroederrock
Oct 10, 2016 11:28 AM
D1030
'10-14 Interior and Audio
Jan 17, 2013 06:52 AM
neil07gt
05-09 Interior and Audio Mods
23
May 21, 2008 06:48 PM
Ugabulldog83
Jun 15, 2006 12:36 PM
shadow
Aftermarket 2005+ Mustangs
Mar 27, 2005 05:12 PM
