Shaft bolts loose :-(
Old Nov 5, 2014 | 11:14 AM
Eliminator.dk's Avatar
TMS Denmark S-197 Fan
Unhappy Shaft bolts loose :-(
Hi.
Just imported this fine Mustang 2005. But in the official inspection ( control ) the inspector notified these shaft bolts were loose. ( see pic. )
Someone here have the right torque for the bolts, and maybe tell me, if they need some loctite.
Thank You.
Have a great day.
Attached Thumbnails Shaft bolts loose  :-(-image.jpg
Old Nov 5, 2014 | 06:34 PM
I believe they do call for Loctite and its not a bad idea IMO to use it either way. Tq spec I would have to google.
Old Nov 5, 2014 | 08:25 PM
GrnT's Avatar
Pics?
Old Nov 6, 2014 | 06:09 AM
KdF's Avatar
KdF
The Haynes manual says 76 ft lbs
Blue Locktite....yea
Old Nov 7, 2014 | 10:44 AM
Torque ?
Anybody know what the torque should be ?
Thanx
Old Nov 7, 2014 | 11:04 AM
Old Nov 7, 2014 | 11:31 AM
Torque
Thank You 😜
Just ordered the Haynes, but still not arrived 😊
Old Nov 7, 2014 | 12:12 PM
KdF's Avatar
KdF
Originally Posted by Glenn
Hey, that's what it says for the flange.......
Old Nov 7, 2014 | 12:27 PM
05YellowGT's Avatar
I think the ???? was for the OP since you had answered it with your post and he asked again.
Old Nov 7, 2014 | 12:28 PM
fer sure
Old Nov 7, 2014 | 12:39 PM
KdF's Avatar
KdF
Ahhhh
Carry on, nothing to see here......
Old Nov 7, 2014 | 03:07 PM
No no , .......I don't aks again. All my questions are solved. :-)
Have a great weekend :-)
Old Nov 8, 2014 | 03:01 AM
76 ft lbs is 103 Nm. Sounds a lot for approx. 1/4" bolts ???
Old Nov 8, 2014 | 03:59 AM
Getportfolio's Avatar
Nothing worse than a loose shaft.
Old Nov 9, 2014 | 01:27 AM
Torque 1/4" bolt ???
Hmmmm , , not happy with 103 Nm for this bolt.
Sure it's right ?
Old Nov 10, 2014 | 11:44 PM
Lime GT's Avatar
http://iihs.net/fsm/?dir=82&viewfile=Driveshaft - 4.6L and 5.4L.pdf
Old Nov 22, 2014 | 04:41 PM
DPHC13's Avatar
did you drive the car and notice anything knocking or clunking because of this? I ask because i'm having a problem and now I'm gonna go check my shaft bolts. When I stroke my shaft I did notice that it had some play
Old Nov 23, 2014 | 02:14 AM
Hi.
No sounds or knocking so far. ......Car is now stored for the winter, so the bolts will be tighten soon :-) ( 55Nm as far as I can see )
Old Nov 23, 2014 | 04:20 AM
David Young's Avatar
When i stroke my shaft i've noticed some play in mine also. I think its normal .
Maybe the last owner had a aluminum driveshaft and installed the factory one when it was sold? Maybe didn't tighten the bolts?
ricky1728
Feb 11, 2016 07:25 PM
Stephen Laslo
V6
Sep 18, 2015 07:57 PM
jim010
Sep 14, 2015 10:15 PM
