Roof Molding... lifting up on one side
Hi all,
I plan to take my car in for warranty work next week, for the rear end squeaking. And I figured I should get this fixed as well..
The Roof Molding on the passenger side at the back is loose (last 4" of it). It pushes down about 1/8"-1/4" and doesn't stay, drivers side is rock solid.
What I'm wondering is how it's a attached ? What will the dealer have to do to remove/reattach/replace this?
If it's simple I would just do it myself.
Thanks all,
Thanks all,
Originally posted by Fastrack@October 28, 2005, 5:51 AM
Hi all,
Thanks all,
Hi all,
Thanks all,
http://forums.bradbarnett.net/index....opic=33454&hl=
If it's still a problem, here's what I discovered.
It's held up by a tip on the moulding that inserts into a clip on the body. If you pull the moulding down slightly and shine a light in there you should see the tip and the hole it goes into, line them both up and then press the moulding flush to the body . . . then give it a tap at the location of the tip with the heal of your hand . . . you should hear the tip click into place and the moulding shouldn't sag there anymore.
Originally posted by The Lyin' King@November 8, 2005, 1:16 PM
You probably got this fixed already. I had the same problem . . .
But the problem above was the actual drainage strips on the roof. The rear on the passenger side wouldn't say down. They fixed it on Thursday, it's held on by 2-sided tape
My car's molding on the passenger side was not fastened properly either. I thought securing that would cure my rattling woes but it did't. Anyway sounds like someone at the plant was sleeping during their new mustang training.
:angry:
:angry:
