rattleing noise?
Old Aug 3, 2012 | 03:03 PM
MikeG2007's Avatar
rattleing noise?
Hey guys I was driving with the top down today and I swear I herd a rattle noise from the driverside...to me it sounds like its in the wheel direction? Any thoughts guys? Y'all have any simiar noises?
Old Aug 9, 2012 | 06:43 PM
driftboatbum's Avatar
Does it stop when you apply the brakes? If so, check your brakes
Old Aug 9, 2012 | 08:41 PM
MikeG2007's Avatar
Didn't think of that
Old Aug 14, 2012 | 03:40 PM
MikeG2007's Avatar
It sounds like a aluminum pan
Old Aug 14, 2012 | 09:33 PM
ford4v429's Avatar
legacy Tms Member
if you can safely get under the car, tap around on the heat shields above the exhaust, and if not there, and it sounds like coming from front wheel, check your sway front bar links- theyre pretty light and when they get a little loose, will rattle like crazy
Old Aug 29, 2012 | 07:04 PM
DPHC13's Avatar
does it make the sound with the rotation of the tire? rock in the tread of the tire?
Old Aug 29, 2012 | 07:05 PM
DPHC13's Avatar
Also are your lugs tight? They make that sound wgen they are loose... don't ask how I know
Old Aug 30, 2012 | 12:54 AM
MikeG2007's Avatar
Ill check thanks bro..
Old Aug 30, 2012 | 06:57 PM
Scrape's Avatar
Wheel bearings or if you are lowered your springs could rattle as well. Broken sway bar bushing as well as a nail in the tire makes weird sounds too.
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
ricky1728
Feb 11, 2016 07:25 PM
khoy37
Sep 15, 2015 07:10 PM
robjh22
Sep 8, 2015 12:31 PM
