Ragg Top over spray
I would try goo gone, the citrus based adhesive remover, since it is safe. If that doesn't work, if you're careful, some adhesive remover, mineral spirits, or even acetone should take it right off, in that order.
TIP: Spray lint free cloth with Raggtop. Use that to dress the convertible top rather than pumping and spraying on to the top itself.
When I did mine I just wiped the overspray off with micro fiber cloths. It was not a big deal as long as the overspray was still wet.
BB
Semper Fi
BB
Semper Fi
When I did mine, I used the blue painters tape and plastic. I basically taped it off like it was going to be painted. It is not that hard of a job but you do it every blue moon so it is worth the effort.
Here's a question for those of you with the cloth top. Are any of you getting white wear spots above the side windows and also on the back corners of the top? I've got 3,500 miles on mine and look at the pictures. The cloth is still actually a nice dark black...it's looks faded because of the flash. The back corner ones are really starting to bother me. Note the wrinkles there too...do your tops have them too?
