Problem with my shaker 500
Old Mar 8, 2005 | 10:16 PM
Skarfunkly's Avatar
i was testing out the shaker with some cd's, i loaded 2 of them, then when i hit load the 3 it said disc error, now i cant do anything with discs, i am going crazy trying to figure out what to do, anyone else ever gotten this problem?
Old Mar 8, 2005 | 10:22 PM
AJC's Avatar
AJC
Some of the earlier production cars have shaker problems - there a thread on it somewhere around here.
anyway in short The way to find out if its a problem system is to turn on the stereo- and hold buttons 3& 6 at the same time - it will go through a test sequence - during the last display you will see a number with a letter - if if shows 'a' then you have the problem cd player- take it to the dealer and have it replaced with the 'b' version.
Old Mar 8, 2005 | 10:26 PM
maucoin65's Avatar
Legacy TMS Member Retired
In the meantime, power off the unit, wait a few moments, then power the unit back on.
I know this sounds too simple to be true, even sounds stupid. But SixtySix suggested that to me the first time my Shaker 500 malfunctioned, and it really works. A few times the unit has skipped or given me a "bad disc" message, or some other malfunction. It appears that somehow the unit gets "confused". Every time I turn it off then back on, it is fine for a long while.
Like Tony / SixtySix wrote, the more computerized our cars become, the more we have to treat them like a computer. So, "reboot" or "restart" your Shaker, and see if that helps.
Of course, if it continues chronically you will have to go to the dealer for a warranty swap out. But try this in the meantime. It has worked great for me!!
Old Mar 8, 2005 | 10:31 PM
Skarfunkly's Avatar
it says B and sum numbers, but its still not working, Cd error, nothing works with CD's on it, i cant eject, load, or even play one
Old Mar 8, 2005 | 10:32 PM
Skarfunkly's Avatar
how do i power off the unit? i took the keys out, and put em back in and it still has a error
Old Mar 8, 2005 | 10:36 PM
maucoin65's Avatar
Simply turn the unit off while it is in CD mode. Push the volume button to turn it off, wait a bit then push the volume button again to turn it on.
I know, and I agree, this sounds moronically simple. But it "reboots" or whatever my unit and straightens it out every time (only happend 2 or 3 times in two weeks; all self burned CDs). Also, take the CDs out and wipe them clean; I am finding that somehow the discs get dirty or dusty while inside the Shaker.
Again, if this doesn't help, or if you cannot eject your CDs, then the problem is more serious and you need to see the dealer. But hopefully this will work for you.
Good luck.
Old Mar 8, 2005 | 10:40 PM
AJC's Avatar
AJC
IF you cant get it to turn off by pushing the volume button you could - Disconnect your battery, wait a few and then reconnect it.. see if that reboots the system
Old Mar 8, 2005 | 10:43 PM
Skarfunkly's Avatar
i hit the button and everything went off on the panel besides the clock, then i hit CD and it said no cd, i tried it again and tried to eject, or load, and it didnt work
Old Mar 8, 2005 | 10:46 PM
AJC's Avatar
AJC
have you tried to select the slot? then wait a few seconds perhaps 5-10 seconds and then try to eject?
I found you can hit buttons too fast with this system and it gets into a loop
Old Mar 8, 2005 | 10:47 PM
Skarfunkly's Avatar
yea ive gone really slow on the procesess, its like no matter which button i pus while in CD mode thing, it always says error
Old Mar 8, 2005 | 10:50 PM
maucoin65's Avatar
I believe I read in an earlier thread that you could NOT tell if it was an early / problem model unit or a late / fixed Series B unit by the last character of the code it gives at the end of the self test.
Sounds like you are in a death loop with this Shaker. Probably time to see your dealer. Sorry.
Old Mar 8, 2005 | 10:51 PM
AJC's Avatar
AJC
Sounds like your going to have to go to the dealer on this then. the only thing left would be to disconnect the car battery and see if it causes the system to totally reset - which is what i would do before taking it in...
maucoin65's Avatar
Just don't panic, that's what the warranty is for. It's still a great car.
Frustrating, discouraging, aggravating, all yes. But fixable under warranty.
Old Mar 8, 2005 | 10:52 PM
Skarfunkly's Avatar
aright, well thanks for the help, i was talking to my dad and hes like let me look at it in the morning, which means ill schedule a thing 2morro lol, i hope i dont have to many problems with the shaker later on,
Old Mar 8, 2005 | 10:57 PM
maucoin65's Avatar
Keep your chin up, Dave. Good luck, with Dad and your dealer.
You'll be fine. Take care.
Rando
Aug 25, 2021 11:12 AM
duppycat
Feb 16, 2019 08:36 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
