Problem with cam cover install
Old Aug 18, 2006 | 10:00 PM
CottonGT's Avatar
We decided on a do-it-ourselves install of some powder coated cam covers on the ‘05 GT. The right side install went OK. On the left side, we were cutting/cleaning the little rubber piece between the accessory cover and the block, when the razor blade slipped and fell down the front accessory drive. It sounded like it fell all of the way down. We bumped the engine over several times with no noise or problems. We have started the engine now and everything seems to be OK. We believe that it has fallen into the oil pan. So, how safe are we to leave just leave it alone in the oil pan?
Old Aug 18, 2006 | 10:32 PM
RedDragon777's Avatar
take it out man...alot of things could happen...like it could rust or could have fallen somewhere else so i will check the oil pan and if it is not there then you have a promblem
Old Aug 18, 2006 | 10:58 PM
WERKED 66's Avatar
that`s a problem......must find out where it went down into...might have to pull your oil pan...
Old Aug 28, 2006 | 06:28 AM
mustang_lurkers's Avatar
Oil Pan
Pulling the oil pan will not be that hard. It will be worth the extra work and save your engine.
Old Aug 31, 2006 | 06:38 PM
Stoenr's Avatar
Is it possible for it to even get to the oil pan?
Funny, I dropped mine when doing the same thing. But I was able to retrieve mine.
sarnold58
Jun 9, 2019 02:22 PM
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
TrueBlue302
Jul 23, 2015 06:13 AM
