Power Seat blowing fuses
Old May 27, 2005 | 04:23 PM
Fastrack's Avatar
Smile
Hi all,
I went outside to install my Redlinegoods leather arm rest I received (Very impressive quality). And standing outside the car I attempted to move the seat forward. No dice! So I popped open the fuse box under the hood.
And fuse 14 (I think) for the power seat was blown. So I swapped the one from the Shaker 500 (same Amp), and the seat worked. I was able to move it UP & Forward all the way... I then moved it all the way back, and down. It blew a fuse when it reached the down position!! I looked under the seat, I don't see any wires that are cut or such. This is all with no one sitting in the seat.
Any ideas ?
I'm guessing one of the motors is shorting out.
At least it's blown in a position I can actually drive! I don't have a stereo any more, not that matters I'll just listen to the engine ... Oh the sound of music
Old May 27, 2005 | 08:05 PM
Fastrack's Avatar
bump... I guess no one else has this problem.
Anyone know if they'll be able to hook up diag to the seat and test it ?
Old May 27, 2005 | 08:15 PM
Infinity's Avatar
You have an intermittent short somewhere. They'll probably have to replace either the seat motor, or a wiring harness. Either way, it's warratied.
Old May 27, 2005 | 08:16 PM
CelticNut's Avatar
Sounds like you're going to have to visit your dealer on Monday.
I'm terrible with things electric. I have a healthy respect for it, and don't really feel comfortable working with it. Wish I could help out!
Let us know what the techs discover...
Old May 27, 2005 | 09:00 PM
Sonic05's Avatar
I'm going to guess you have a shorted motor. They should be able to use an amp probe to find which motor is bad . . . or where the short is. 1 hour job.
Old May 27, 2005 | 09:02 PM
Fastrack's Avatar
Sweet that makes me feel better!
Old May 27, 2005 | 09:20 PM
Mr. 'Stangster's Avatar
They should have used a mini breaker instead of a fuse. Alot of Ford vehicles use (used to use ?) mini 12v breakers for electric windows and power seats. The reasoning was that when either a window mechanism or seat mechanism reaches full travel the motor can't go any further and loads up (amperage increases dramatically) and would blow the fuse. With a mini breaker it just trips and resets itself automatically. Some new vehicles have a built in microswitch that cuts off the power at full travel so this doesn't happen. The high tech way is for a "brain" to detect the amperage draw and cut the power off at full cycle. I don't know how the mustang seats are set up, but a mini breaker of the same rating would definitely help in a case such as this. I would take it to the dealer first and if they can't or won't fix it I'd go the breaker route. They are usually available at a good auto parts store or electronics store. :drive:
Old May 27, 2005 | 09:24 PM
Fastrack's Avatar
That sounds like a great idea, I'll have to see what the dealer says.
Old May 29, 2005 | 02:44 PM
houtex's Avatar
Remember that scene in "Trains, Planes, and Automobiles" whereby John Candy is trying to get the seat "just right?"
Yeah. Couldn't be something like that, could it?
j/k
/no way I actually know. You're prolly under 180 Lbs, or 82 kg, right?
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Fedupdave42169
Oct 23, 2015 09:58 AM
