Pedders Camber Plates: Important info about thrust bearings
Old Jan 31, 2022 | 01:21 PM
2007CalSpec's Avatar
Hey guys,
As owners of Pedders camber plates, you probably know that it doesn't come with thrust bearings to eliminate spring bind and popping when turning. Even though the instructions don't mention the reuse of the thrust bearings and spring perch that comes with your XA coilovers, you can definitely use them according to Pedders when I emailed them about it.
Thrust bearings on original tophat
Thrust bearings removed
Old Feb 4, 2022 | 05:57 AM
NeoGeo630's Avatar
Well that would have been good info to include in the instructions! Curious, how are you adjusting the plates when they’re on your car given you can’t access the adjustment nuts?
I had my camber plates on for less than 6 months, didn’t even have them adjusted at all, and barely even drove my Stang due to covid and wfh. Had them removed because ultimately decided I’m not going to be messing with my camber much if at all.
Anyone interested in a practically brand new set of the camber plates, dm me.
Old Feb 12, 2022 | 09:23 PM
I can't adjust the camber plates with them installed. I got lucky on the first try and got the camber where I wanted it.
Old Feb 12, 2022 | 09:24 PM
Finally had some time today to install the original thrust bearings on top and a Jegs thrust bearing on the bottom. I originally had the Jegs piece on top and nothing on the bottom, which worked, but I wanted to do top and bottom since Pedders suggested I move the Jegs piece to the bottom and use the original one on top so the spring will move fully independent of the strut.
Video of fully independent spring movement.
adam81
2012-2013 BOSS 302
16
Oct 16, 2011 10:09 PM
Redfire 05Gt
13
Jun 3, 2005 05:48 PM
