Outer door handle not retracting.
Old Jan 17, 2006 | 01:31 AM
Giddyup's Avatar
I searched and found that several people have experienced door handle(s) that aren't retracting fully. Anyone that has had theirs fixed......do they have to pull the inner door panel to do the fix?
Old Jan 17, 2006 | 04:13 AM
vc4life's Avatar
just had mine done a few days ago and yes they do have to pull the inner door panel off to fix it. they messed up one of my door panel pieces and although they are going to replace the piece they messed up it still sucks they didnt take there time and were not carefull with my baby. so watch out for scratches and stuff on the door panel after they replace the outside door handle
Old Jan 17, 2006 | 02:18 PM
MustC's Avatar
I just got my car back from the dealer this afternoon after having the handle replaced on the driver's door. Although I left it there Sunday night, they didn't get all the work done on Monday, so they gave me a loaner and finished it today (Tuesday). As the earlier poster noted, the length of the job is longer because they have to remove the inner panel and window glass.
The handle is OK; I did notice that that the inside panel is no longer flush with the holder for the inner door handle. In other words, when they pulled the inner handle insert, it didn't go back in place just right. At this point, however, it's not worth hassling with them again for what appears to be just a cosmetic flaw.
Old Feb 20, 2006 | 12:03 PM
rodneylynn1977's Avatar
<div class='quotetop'>QUOTE(MustC @ January 17, 2006, 3:21 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Mine are now doing the same think, gotta find the time to take the car in!!!
Old Feb 21, 2006 | 03:42 PM
WB05stang's Avatar
I had mine done about a month ago. They pulled the door panel off and were able to adjust it. I have had no problem since then.
Old Feb 21, 2006 | 09:43 PM
Lime GT's Avatar
Anyone know exactly what they do for the repair or do they just replace the whole handle assembly?
Old Feb 22, 2006 | 04:45 AM
MTAS's Avatar
<div class='quotetop'>QUOTE(MustC @ January 17, 2006, 4:21 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Mine does it, but there aint no way I'm leaving the car there for 2 days unsupervised. I'll live with it - like you said, it's cosmetic any way.
Old Feb 23, 2006 | 09:07 AM
WB05stang's Avatar
When I had mine done they just had to adjust a rod inside of the door. The tech that did it said they did have to replace it on another car. So I think it really bepends on what is wrong.
Mine was just sticking out in the back. The other one was sticking out in the front and back.
Old Feb 24, 2006 | 10:33 PM
GottaHaveIt's Avatar
<div class='quotetop'>QUOTE(WB05stang @ February 23, 2006, 8:10 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
My spingy thingy inside broke, so they ordered a whole new assembly which had to have a new door handle as well which I thought a tad brighter ! it only happened on the drivers door as i guess it's used more ?
Old Feb 26, 2006 | 12:35 AM
Lime GT's Avatar
<div class='quotetop'>QUOTE(MTAS @ February 22, 2006, 5:48 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
My drivers side handle is hanging out a bit. If I take it in I'll be removing the door panel and various parts first to give them access to the handle so they don't damage the panel in they're hast. When I had the radio replaced under a tsb, I advised the service rep I'd be removing the console and various panels as well before taking it in for the radio change after making my appointment. They had no problem with that.
NC14GT
Sep 10, 2017 04:47 PM
RCooke08GT
Feb 19, 2017 03:03 AM
GeoWett
Sep 30, 2015 06:40 AM
Ray11
Sep 25, 2015 12:43 PM
