One piece driveshaft: Which one do I buy???
Old Aug 22, 2016 | 05:41 PM
wileycoyote05's Avatar
Hey all,
Looking into buying a 1 piece shaft for my 05 GT (manual trans) as my xmsn went out last week and the U-joint in my stock driveshaft is slinging grease (probable cause is bad bearings in the transmission which I'm waiting on parts to replace/overhaul, came to this conclusion as the transmission is softly grinding/not running right and spitting ATF out of the output shaft seal...bad seal, bad u-joint = bad bearing)
Anyway, the U-Joint is the "pressed" non-serviceable kind, plus I've been reading that the one piece design is great.
My questions is this: I'm not looking to make the car incredibly faster (until I get a job that pays more money....) but would like any input on a one piece design. I've read the driveshaft shop is great, etc. But there seems to be no general consensus on which is preferred for a stock (not lowered) s197.
Any tips/pointers/pros would be greatly appreciated.
Thanks!
Old Aug 22, 2016 | 06:58 PM
redonblackpony's Avatar
Shaftmasters is a great inexpensive choice. It runs several hundred dollars cheaper than its competitors and is A quality piece
Old Aug 23, 2016 | 06:50 AM
That is what I have been running for years! Plus I got a free Shaftmasters T shirt. The ladies know it all ready but I like wearing the shirt anyway. HA
Old Aug 24, 2016 | 09:12 PM
Steered me to the right place, ordered my DS and awaiting the long shipment from MI to Hawaii (twiddles thumbs)
Lol thanks y'all.
Old Aug 29, 2016 | 12:05 PM
07 Boss's Avatar
The only big differences between most of these one piece shafts is the diameter and the rear pinion flange U-joint. Some models will have a 6 bolt flange (direct bolt) and other will have a regular 4-bolt u-joint and an adapter plate. I have had shops tell me they don't like the adapter plates but I have never had an issue with mine, something about vibration and balancing. Diameter on the aluminum shafts will effect rotational mass and strength. My next driveshaft (for another build) will be carbon fiber for strength.
Old Aug 29, 2016 | 12:09 PM
SpectreH's Avatar
It was probably overkill, but I went carbon fiber when I installed the ProCharger.
Old Aug 29, 2016 | 03:01 PM
650 total spent on a direct bolt in. Welds look solid, like the counterweights (lets me know they balanced it) and love the idea of the snap ring U joints so I can actually service it 😂
As far as the aluminum vs carbon fiber debate...we used aluminum driveshafts on the helicopters i worked on in the Corps. They held up very well at 1400+ RPMs. Carbon fiber I'm skeptical of because of things like delamination if any scrapes or nicks occur. Maybe i'm just talking out of my butt.😲😊
Old Aug 30, 2016 | 08:41 AM
Well how does it Feeeeeeeeeeeeeeel?
Old Aug 30, 2016 | 05:31 PM
I'm still waiting on motor mounts, transmission mount, headers and oxygen sensors in the mail till I get to put the pony back on the road. 😪 will post with an update as soon as I get it all put together!
Old Sep 1, 2016 | 04:18 PM
MadcapMagician's Avatar
Oh my God the wait is killing us!!!
Old Sep 2, 2016 | 07:13 AM
you removed all those parts without having the replacement parts in hand? That's crazy talk
Old Sep 9, 2016 | 06:03 PM
Yeah this has been a pretty taxing process. Dropping a transmission by myself has been a pain in the butt. My colorful vocabulary has certainly been getting practice. I'll probably bump this thread up with a detailed write-up of everything I did and learned, which is a LOT.
Old Sep 9, 2016 | 08:23 PM
Tranny jack really helps and makes it easier
Old Sep 9, 2016 | 08:25 PM
Spot on. I ended up using a motorcycle jack which wasn't too bad all thoughts considered.
Old Sep 9, 2016 | 08:27 PM
The main thing is getting the car high enough off the ground to get the tranny out from under it
Old Sep 16, 2016 | 03:33 AM
Verdict is in:
The stang runs great.
This all initially kicked off from the tranny giving a soft whining/grinding in gear.
Parts replaced:
Clutch
Flywheel
Pilot bearing
Throw out bearing all from LUK clutches. Very smooth OEM feel.
The install process was a PITA as the car was on 3 ton jackstands and I dropped the xmsn with a motorcycle jack. The dropping was less troublesome than the reinstallation. My advice for those planning to change their clutch: either invest in a transmission jack or a transmission jack adapter. Also....don't do this on jack stands. Go somewhere with a lift. 😂
The process I took in dropping the Trans was as follows:
Disconnect H pipe. I DID NOT remove the oxygen sensors as the car had 125k miles and the entire exhaust was stock (the cats on the H pipe were rattling as the filtrous material inside was dust).
I ended up snapping one of the pressed in header bolts and this ordered new headers. After doing research I learned that aftermarket shorties often colide with the steering shaft if the engine mounts are old--so I ordered some a those too. 😀
Remove driveshaft
Remove wire harness on xmsn
Drain xmsn (first time servicing the tranny--it needed to be serviced)
Remove xmsn crossmember/mount
Remove starter
Remove hydraulic clutch to Throw out bearing line. I suggest you get a hydraulic line cap, otherwise your clutch will "self bleed" 😂
Remove bellhousing bolts: protip-- BUY 1/2 DRIVE EXTENSIONS AND AN IMPACT DRIVER. I had about 2 feet of extensions and an impact universal socket. A little stiffer than universal joint + socket so less flexion for the top 2 bolt. Also, I sprayed, resprayed, and sprayed again all the bellhousing bolts and the flange around the bellhousing with a rust penetrating lubricant. I recommend freeze off. Note: if you do this, your clutch and flywheel absolutely must be cleaned with brake cleaner if you don't replace it as the lubricating oils will contaminate your clutch.
I had the motorcycle jack under the transmission at all times-- safety first. 👍
A little jerking and some prying got the veryrusted transmission broke free.
The clutch replacement went fine. I'll attach photos of the old clutch and flywheel. It was shot, multiple hotspots and glazing, and the clutch was coming apart. When removing the pilot bearing USE A SLIDE HAMMER AND THE PILOT BEARING PULLER!!! I rented one from a parts store for "free". The grease/bread/putty/towel method does not work. Trust me.
Slapped it all back together. Wear latex or nitrile gloves when handling clutch parts, clean liberally with brake cleaner, so as not to contaminate with oils from your hands.
While the Trans was out I replaced the headers and motor mounts. I suggest you do this as well if you're looking to upgrade.
Reinstalling the transmission I balanced the rear of the tranny on the motorcycle jack and used a 2 and 1/2 ton jack to jack the bellhousing portion to put the tranny at a 35 degree slant so that the input shaft didn't damage the fingers of the pressure plate. After the shaft cleared the fingers, I edged it forward while slowly raising the back of the transmission so it leveled out, allowing the input shaft to engage the clutch teeth without gouging them. Guide it onto the bushings on the engine. Make sure gap around bellhousing to engine remains even before seating transmission. To ensure input shaft teeth engage clutch and pilot bearing turn the output flange of the transmission intermittently.
To make sure the transmission doesn't roll on the input shaft before it's seated on dowels on engine, I put screwdrivers through the bolt holes.
And reinstall the rest opposite of removal.
Single piece aluminum driveshaft from. shaftmasters. I'm VERY pleased with the driveshaft response--hardly any backlash or clunk when taking off from first.
BBK shorties and BBK catted x-pipe (and new oxygen sensors) -- the drivers side header will contact your steering shaft, even with new motor mounts. I dimpled the header where the shaft was rubbing with a mallet and half inch drive extension. Sound is raspy and nice.
Steeda motor mounts (poly) : PITA to install correctly. I was cursing steeda the entire install.
Overall, increase in responsiveness and the transmission sound has been solved.
Hope this helps some folks, if y'all have any questions just let me know.
Here's some pictures from the install:
Old Sep 16, 2016 | 07:32 AM
tj@steeda's Avatar
Verdict is in:
Parts replaced:
Clutch
Flywheel
Pilot bearing
Remove driveshaft
Remove starter
But once installed ... you were giving praise, right?
Best Regards,
TJ
Old Sep 22, 2016 | 02:11 PM
mrkabc's Avatar
This is great stuff! Wiley, you are inspiring me as well, since I need to get my clutch done. I'm getting the Exedy clutch kit. You got the Shaftmasters driveshaft? Where do I get a hydraulic line cap?
I don't care about replacing the exhaust manifolds (I'm in Commiefornia, the smog ***** will come knocking) but the motor mount replacement is a good idea. What was wrong with the Steeda mounts?
Didn't see pix? I am highly interested since this will be my project in the next couple of weeks.
Old Sep 22, 2016 | 02:29 PM
The Steeda mounts are great products, however I had a little trouble getting the center bolt through the mounts to bracket, as the engine had shifted quite a bit because I removed the mounts to make dropping the Trans a little easier (oops...try to avoid doing that) and thus had to buy a cherry picker (HAD TO is what I told the wife &#128514 to move the engine a little.
As far as the headers, the BBK shorties are carb certified. Unfortunately...the catted x pipe is not. But I'm keeping the stock h pipe. As for the line cap, should be able to pick them up at an auto parts store, or be prepared to have an oil catch pan under the line.
And the shaftmasters shaft: easy quick install. Great driveshaft, looks and feels great.
Old clutch and flywheel....bahaha
Oooh shiny.
The claaawwww
Old Sep 22, 2016 | 02:37 PM
Also...watch this video! It saved my behind in the whole process.
And protip! Bag and label all your parts as you remove them. Nothing worse than looking for the little clip for the hydraulic line and Not being able to find it.
