Oil change timeframe for a pleasure car
Old 1/25/07, 07:38 PM
Entil'Zha's Avatar
My car is a daily driver, and I'm averaging about 100-120 miles a month. I figure I should do my first oil change(depending on how it looks)at the 6 month mark to full synthetic, and then change it every 6 to 9 months. What do you guys think? Can I go as long as a year or what???
Old 1/25/07, 07:57 PM
kevinb120's Avatar
Every 6-months to a year if its synthetic is fine. If you start/drive it regularly it shouldn't be that big an issue. If its the stock oil its probably synth blend but I would change it now.
Old 1/25/07, 08:37 PM
Entil'Zha's Avatar
Thanks Kevin, My car is a 2007, almost 2 months old, so its the stock oil.
Old 1/25/07, 08:40 PM
shatter's Avatar
I changed my oil after I had like 150 miles on it or so to get all the engine break-in crud out of the system. Since you're not putting a lot of miles on the car, you might think of doing an early oil change for the same reason.
Old 1/25/07, 08:55 PM
Mike McRann's Avatar
I take my car in every six-months for service since I drive between 7500 and 9000 miles a year.
Old 1/26/07, 02:29 AM
theedge67's Avatar
I put about 55 miles a day on my car, 95% interstate at 70mph. I change it at 10,000 with Mobil 1 and Mobil 1's Extended Performance synthetic filter. When I changed it last, it was getting dark, but it wasn't bad...just a med-dark brown. Firm believer in extended drain intervals with GOOD synthetic oil, and a GOOD synthetic filter.
Old 1/26/07, 06:30 AM
9 is not my lucky number.
dustindu4's Avatar
V6s require a hamster change every 2000 miles
Old 1/26/07, 09:03 AM
just because oil is dirty looking does not mean it needs to be changed or that its bad. Mobil one was tested and still in good shape at 18k on a test of a v8 car. Once a year or every 10k miles and you are still more than safe. Don't waste it only drives the price of oil up LOL
Old 1/26/07, 10:01 AM
RKNMACH's Avatar
I've got just over 9,000 miles on mine (about 17 months) and I've been using the 5-20 oil the manual recommends and changing the oil and filter (myself) @ 2,500 mile intervals. When I hit 10,000 I'm switching to Mobil 1 and going to 5,000 mile intervals and upgrading the filter (no more Frams for me).
Old 1/26/07, 10:34 AM
blkstang06's Avatar
My 06 GT ( Build Date 06/02/06) one of the last 06"s built! I have 3200 miles on it! At 100 miles Changed to Royal Purple 5-20 and Ford Racing Filter! At 3500 I will Change oil and Filter! and continue that interval for as long as I own the stang!..........All motor oil's degenerate synthetic or otherwise Due to three factors Heat, Dirt-( foreign or internal particles)and Time!....When a motor oil Changes color! especially in a new motor! the reason is heat!........Yes! its cookin'.....and when this happens the viscosity changes for one! and components of the oil start to separate!........as in that 1/8'' of tar found in the oil pan of older engines!.. that also coats internal engine parts and clogs oil ports! slows oil flow creates more friction and wear!
Old 1/26/07, 10:36 AM
TMS Post # 1,000,000
Serbian Steamer
Zastava_101's Avatar
I had my Mustang for 6-7 years and I always changed oil every 3,000 miles.
Old 1/26/07, 11:49 AM
KdF
KdF's Avatar
I changed mine at 500 , then 1500 , and again at 3000.
I will change it now every 3000 as well.
I use the Motorcraft oil and filter just to stay in warranty.
As of today I have 3786 miles and I got it March 17/06.
Old 1/26/07, 02:08 PM
kevinb120's Avatar
I'm a slave driver so I expect 4000 miles out of my hamsters. Mine's in the shop today, those suckers get dirty. They looked pretty **** tired too. I'm taking them home though, going to clean them up, pamper and feed them, then let my cats have at em...
Ecostang
11/3/22 08:50 PM
jc46002003
4/15/16 03:00 PM
bigaaron
1994-2004 V-8
8/22/15 12:06 PM
Mackitude
8/13/15 01:05 PM
TripleBlack14
8/10/15 10:25 AM
Quick Reply: Oil change timeframe for a pleasure car
