Noisy passenger window seal - wind noise
Old Oct 12, 2005 | 11:25 AM
HolyPony!'s Avatar
Hi, just wanted to know if anyone has had this problem and found a fix for it...
The window seal for the passenger door seems to be leaking on my car. It keeps the water out, but when I drive at highway speed I always hear wind noise. It is worse when I open the window and close it, and it is less severe when I open and close the door, probably because of the window going down then up a litle.
I took it to the dealer 3 times now and they just said they can't fix it because of the design of the "frameless" door (but the driver's door is OK ). Hard to follow their logic sometimes :scratch:
Old Oct 12, 2005 | 12:40 PM
cyoon's Avatar
You'd probably have to redo the padding for the top of the door to fix the issue. I had this on my truck with a similar design. Also, you might be able to adjust the window so it stays flush against the top of the door. That might be hard to do. I've never done that myself.
Old Oct 12, 2005 | 07:20 PM
dcranford's Avatar
I am experiencing the same exact thing on my mustang as well.
Passenger side and all. It seems to only really show itself once above 40MPH+
I hadn't taken it to the dealer yet.
Although I have to get my visor replaced...so maybe when I go in for that Ill see if they can do anything.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
ricky1728
Feb 11, 2016 07:25 PM
