New Vert owner w/ a couple of questions
Old Apr 27, 2005 | 06:02 AM
mypony's Avatar
Just noticed the top will go down or up with the key off, is that by design? The manual says to have the key on, but ours appears to be hooked into the accesory delay circuit.
Also, there is some blue plastic tape on the weatherstripping. I assume this was there for delivery/shipping only, but thought I would check before I peel it off.
Old Apr 27, 2005 | 09:35 AM
PottyScotty's Avatar
The blue tape is from the factory. My dealer pulled it off (the few pieces that were missed by the detailing guys) as he handed me the keys.
The manual says to have the car running so operating the top doesn't drain the battery. I think I actually had the key out of the ignition and then put the top up after pulling into my garage. There may be a delay in the circuit to allow for this.
Old Apr 27, 2005 | 09:36 AM
ddanimal's Avatar
Yeah, you can open/close with the key in and car off, its just not recommended. It seems to take a little longer though without the extra juice.
Blue stuff must be delivery/shipping only, I don't have any.
Did you check your rear window? Was it fully glued/sealed? Mine is separated on the bottom. The top on the outer side of the glass was separated. I'm hoping to get it fixed at 3000 miles.
Old Apr 27, 2005 | 10:52 AM
moze's Avatar
The blue stuff is definately from assembly. Go ahead and remove it.
Top up and down with the engine off is not recommended because it drains the battery. You can do it, but it uses a LOT of juice. You should do it with the engine on whenever possible.
ustabawannab
May 3, 2016 07:54 AM
mrp5150
Aug 23, 2015 06:29 AM
redneb
Aug 10, 2015 12:25 PM
junkman9096
Aug 3, 2015 10:58 AM
pretender
2011 - 2014 GT/CS
Jul 17, 2015 03:29 PM
