new plugs
Old Mar 8, 2008 | 05:46 PM
frdfrst's Avatar
new plugs
just bought new motorcraft plugs sp462.they said there one piece.kinda look the same.
Attached Thumbnails new plugs-dscn0580.jpg   new plugs-dscn0586.jpg   new plugs-dscn0591.jpg   new plugs-dscn0592.jpg   new plugs-dscn0593.jpg
Old Mar 8, 2008 | 10:44 PM
302svt's Avatar
They look the same to me also.
Old Mar 9, 2008 | 12:00 PM
06GT4RAD's Avatar
Agreed
Old Mar 9, 2008 | 01:58 PM
polodinks's Avatar
see what i see 2 plugs.... lol look the same
Old Mar 9, 2008 | 02:19 PM
Stoenr's Avatar
Part #'s cross for me, and the motorcraft ones are actually cheaper, wow.
It the difference in the gap's listed that has me worried
SP462 Spark Plug Retail 17.65 Cost 7.15 Gap .054 ?
HT1 Spark Plug Retail 22.18 Cost 8.94 Gap .045 ?
OE Style; REVOLUTION HT is specifically designed for the
Ford Triton 3 valve Eng design
Old Mar 9, 2008 | 02:21 PM
karman's Avatar
Who "they" said those are one piece?
Stock plugs s/b Autolite HT1
HT1s are Autolite ,SP462 are Motorcraft. Same plug, but the gap may be a hair different. I believe HT1 s/b .045 and SP462 s/b .054
Both are 2 piece plugs.
Old Mar 9, 2008 | 02:46 PM
m05fastbackGT's Avatar
Hope this doesn't sound like a dumb question, but could our 3v heads be swapped for 4v heads from the 03/04 Mach 1. That's providing their compatible
Old Mar 9, 2008 | 04:26 PM
karman's Avatar
Not a dumb question, but I think you would get a better response posting a new thread on it.
Old Mar 9, 2008 | 05:54 PM
The reason for posting that question. I was thinking it could possibly be an alternative/solution, for the one piece spark plug issues.
Old Mar 9, 2008 | 07:35 PM
goldenpony's Avatar
Plugs
I believe the only choice for a 1 piece design plug are Brisk and Champion (#7989). The Champions are double platinum and should last a very long time. You can see the Champions @ sparkplugs.com.
Old Mar 9, 2008 | 09:45 PM
06GT4RAD's Avatar
Never been a fan of Champion Plugs.
Old Mar 10, 2008 | 10:20 AM
Robbieg's Avatar
Champion #7989
Old Mar 10, 2008 | 12:23 PM
GTMark052's Avatar
Has anyone tried the new Champion plugs to see how they run in our cars???
I'm still scared to remove my stock plugs but I know that it has to be done sooner or later.
Old Mar 10, 2008 | 03:15 PM
goldenpony's Avatar
Champion Plug
I've never been a fan of broken plugs either.
Old Mar 10, 2008 | 04:20 PM
06GT4RAD's Avatar
Yeah me neither. Also never been a fan of plugs blowing out of the head. This isn't the first time Ford has had a issue regarding spark plugs. You would think they would have learned their lesson by now but it seems not. I already had one of their spark plug issues cost me 6k to get fixed. This time I purchased the extended warranty and they will pay for it this time around.
Old Mar 13, 2008 | 10:28 PM
randy_tho's Avatar
What are the details on the blowout?
Over 150 dollars for a set of plugs is ridiculous. (Almost as ridiculous as using a flawed design for years.) Are the OEMs regular platinum. I got the iridium NGK plugs for my stealth and they were just like 6 bucks a piece. So the champion plugs would carry the same change interval as the stockers?
Old Mar 14, 2008 | 05:05 AM
metroplex's Avatar
Someone needs to make an iridium 1-piece plug for the 3V cylinder heads. Iridium will last longer than platinum.
Old Mar 14, 2008 | 08:04 AM
06GT4RAD's Avatar
Had a spark plug blow out of my head on my F-150 it ended up damaging the piston as welll so i had to have the engine replaced. All 1k out of warranty. Cost a tad over 6k for that one. That is why i went with the Extended warranty this time.
Alos regardless of what plug you use iridium or pltinum do not leave them in the car for more than 50k. Plugs do not last 100k I can assure you. And some when you try to get them out at 100k won't come out
Old Mar 14, 2008 | 08:21 AM
adrenalin's Avatar
I'm thinking about changing my plugs but I am a bit concerned after reading all the posts about the plugs breaking off in the head when removing them. My car has 60,000km (which I think is approx 38,000 miles). Do you think there would be too much carbon build up by now and cause them to break? I am use to working on older vehicles where this has never been a problem.
Old Mar 14, 2008 | 09:00 AM
06GT4RAD's Avatar
Go to this link clikc on Episode 26 and watch the vid it tells you how to go about removing the plug safely.
http://www.flatratetech.com/index.php?categoryid=4
Sep 23, 2015 03:21 PM
devildog1679
'10-14 Interior and Audio
Sep 14, 2015 02:17 PM
