Need opinion on some pedals
Old Sep 12, 2007 | 05:03 PM
Anonimac's Avatar
Question Need opinion on some pedals
I really like these pedals from MossMustang.com (apparently made by Cobalt)...
http://www.mossmustang.com/Shop/View...eIndexID=60325
Anyone have any experience with them? Quality? Appearance?
I can't seem to find any pics of them installed so if anyone knows of some pics please link. And how do these install?
Thanks.
Old Sep 12, 2007 | 05:07 PM
pantera72's Avatar
I would go with the GT500 pedal covers since they slip right on and replace the current pads. The ones you listed look like the pedal covers that require holes to be drilled in the pedals.
Old Sep 12, 2007 | 05:28 PM
ShowGT's Avatar
I agree, each to his own but for OEM fit and looks the GT500 pedals can't be beat if you get them from Craig @ Aac4parts@aol.com
Old Sep 12, 2007 | 06:11 PM
Anonimac's Avatar
Appreciate the tips...i'll be honest, i just don't really care for the GT500 pedals, but i appreciate the advice.
Old Sep 12, 2007 | 07:53 PM
shaun_beauchamp's Avatar
Got mine from Autovation (www.autovation.net) and they are very similar to the images you have posted. What I like about them is where the holes are cut through, the raised edge grabs well on my shoes. Even with wet shoes I have no issues with brake, clutch, or gas pedals. I opted to skip the dead pedal since when I depressed the clutch my outside sole hit the dead pedal and limited the full travel.
I like the designs of those you posted, but I cannot attest for the quality of anything but Autovation. I haven't contacted Autovation lately, but they could offer newer designs. You may want to check them out. You can also check my site www.beauchampengineering.net for more info.
Later,
Shaun
Old Sep 12, 2007 | 08:57 PM
Anonimac's Avatar
Later,
Shaun
Hey Shaun, thanks for the links...the Autovation stuff looks really nice and your site is really good too. Great mods on your car, i have like 80% of the same stuff done (i.e. CDC ducktail, cupholder bezel and rear emblem from SHC, like everything from MGW (lol) including the short throw shifter, etc...). Unless someone convinces me otherwise i think i'm gonna get the pedals from Moss Mustang. I really like the look, quality looks top notch, and i like the way the "GT" lettering looks.
Anyone else have any input?
Old Sep 13, 2007 | 06:10 AM
pachary's Avatar
I like my roush pedals, don't know if you'd want em on a non-Roush car or not.
Paul
Old Sep 13, 2007 | 11:45 AM
mot250's Avatar
Thanks.
Too bad I already have the Steeda pedals. Those Moss pedals look pretty cool .
If the mounting method is as similar to the Steeda pedals as it appears, you first remove the rubber covers from the clutch and brake pedals, then drill and attach the aluminum cover. Put the rubber covers aside in case you want to put them back on or throw them away. If you reinstall the rubber covers later, you won't see the holes.
Our gas pedal/arm is plastic and is one piece with no rubber cover. Once you drill this, the holes are there until you repace the assembly.
They are also similar in cost to the Steeda pedals
Use the pedals as a template and mark the holes with a sharpie or something.
To drill the stock pedals, put a block of wood between the pedal and the floor to hold the pedal in position. It is best to use a center punch so the drill bit doesn't walk-around before starting the hole.
Then just bolt them on and enjoy happy feet!
Not sure how the Moss dead pedal mounts. The Steeda dead pedal included a bracket that uses and existing bolt on the left side of the foot well. Need to peal bach the carpet and remove the kick-panel to access the bolt but it all goes back in place when you are done.
Old Sep 13, 2007 | 12:47 PM
I like the Roush
Old Sep 14, 2007 | 05:55 AM
pachary's Avatar
Boy that Steeda install sounds an awful lot like the Roush. Wonder which came first, the chicken or the egg!
Paul
Old Sep 14, 2007 | 06:06 AM
TheRealOne's Avatar
If I had not gotten mine already from UPR I would get those from Moss. They look pretty sweet.
Old Sep 14, 2007 | 08:09 AM
Anonimac's Avatar
Bought them last night...hopefully the look as good in person as they do on the website.
Old Sep 14, 2007 | 09:55 AM
kevinb120's Avatar
The GT500/Premier trim group pedal covers are slippery as hell if your shoes are even remotely wet.
Old Sep 14, 2007 | 01:07 PM
Anonimac's Avatar
They look that way....very smooth. I'm hoping some of the "grit" on the pedals i bought will take care of that and the raised screw holes. Other than that, i just think they look good...go figure.
Old Sep 14, 2007 | 01:21 PM
MrClean's Avatar
Here's what I ordered (they're on the way via UPS) Clutch and Brake Pedals and Gas Pedal W/Heel-Toe Extension
The finish I selected was the Frosted Anti-Slip without Rubber Grip Insert (the rubber inserts wear down, and actually are more slippery).
I heel/toe to match revs every single time I downshift while also needing to brake, so this was a good alternative. I realize they're a little pricey, but I really like the frosted anti-slip surface.
For the clutch/brake pedals, the OEM rubber pad needs to be removed, but for the gas pedal, it fits right over the OEM (because it's plastic), which also raises the level a smidge, which in turn makes the heel/toe easier.
Old Sep 14, 2007 | 03:42 PM
Anonimac's Avatar
lol, you said "frosty"... ...not sure that word belongs next to any Mustang accessories.
jokes aside, great pedals, i definitely looked at those and like them A LOT. I just didn't want to spend that much on pedals and then ran into the ones i got from Moss Mustang. You definitely got a great set. Congrats!
Old Sep 14, 2007 | 07:21 PM
SkyMaster19's Avatar
Check out ultimatepedals.com.....first rate, not the cheapest but excellent quality
Old Sep 15, 2007 | 08:50 PM
MrClean's Avatar
Thanks! Actually I wrote "frosted", not "frosty"....hardened female nipples come to mind with that word...
Um, check out the links in my post above........
Old Sep 18, 2007 | 05:35 PM
nonstopred's Avatar
http://forums.bradbarnett.net/showthread.php?t=70625 +1 on the gt500 pedals....38 bux on ebay
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
CoyotePremium13
Oct 7, 2015 07:17 PM
Ray11
Sep 25, 2015 12:43 PM
Sep 23, 2015 03:21 PM
