Need Advice!
Need Advice!
I recently installed H&R Race Springs on my 2006, I love the look but the rear is bottoming out some. I used my stock shocks. Does anyone have any suggestions on what I could do to eliminate this issue?
The stock dampers don't like being lowered at all. You will probably want to get upgraded shocks/struts.
Hey H,
This question is tough to answer as it could be a few different things.
It could definitely be that your stock shocks and struts cannot handle that drastic of a drop and are causing you to bottom out, which a quality after-market shock and strut kit would remedy for you!
It could also be that you are hitting your bump stops. Did you swap them or do you still have the factory bump stops?
If you are still running the factory bump stops, I would recommend cutting them in half!
Hope this helps and let me know if you have any questions.
-Will
Eibach even states on their website they R&D their spring kits with the stock dampers and are recommended for both performance and stock damper applications and are backed by their full lifetime warranty..
However when the time finally does come to replace them, I'll be upgrading to Koni yellows as I want to upgrade to an adjustable damper which hopefully will reduce that annoying wheel hop in the process as well
It isnt suspension issues, it is uncontrolled bounce and jounce as the tuned for stock height dampeners try to 'seek' to stock height... but cant due to the new lowered height.
If you dont have that... amazing. If you are ok with it, cool.
Myself, i got tired of the wallowy, scraping/slamming speed bumps issues with the stock on 1" lower and vot the koni orange. World. Of. Difference.
Well here's what doesn't make sense to me ! Even Koni states their street/orange dampers are tuned specifically for lowering spring applications but can be also be used to improve ride performance quality with OEM stock springs as well..
So wouldn't you think if your stock dampers aren't able to compensate for the lower spring rates, the same would also apply if using higher OEM spring rates for dampers that are intended for lower spring rate applications ?
Maybe I'm just over analyzing and reading more into it than what I should, but it seems to me that some of these aftermarket companies have this tendency to contradict themselves whenever it comes to marketing their products
The reason the Konis work with any car is that they dampen for *any* height, not just the 'best' as the stock ones are set to do.
Again, the stock ones WANT to have the car at the stock height. They're valved for that, and to allow movement elsewhere to get it to that height. Which is why they're crap anywhere else. Oh, they'll eventually calm the car down after the 3rd bounce, sure... or is it the springs? :shrug:
But the Konis don't care about height. Car can be anywhere in that respect. They care about stopping the motion, *period*. So stock, 1", or even 2" down, and it's going to stop that car moving, and let the spring completely dictate the car's final stop.
The result is a stiffer, more immediate bounce/jounce dampening, versus the stock one that might oscillate just a tad more, but ride smoother for it.
Their explanation really didn't make any logical sense to me and here's why..
1] If the design of the stock dampers are set and valved for only the height of the stock springs, then how in the hell can they really work on a lowering spring kit application let alone be compatible as Eibach supposedly claims according to their own R&D test results
2] If their lowering spring kits are really so compatible with the stock dampers, then why even bother to design an Eibach dampering kit as either a direct replacement or an upgrade over the stock dampers to begin with ?
Seems to me there has to be logical reason, but once again Eibach was unable to provide any straight forward answers to these questions, but thanks to you, I finally have the answers I've been long searching for..
Therefore with that being said ! I plan on upgrading to Koni Yellow struts/shocks A.S.A.P
Antigini-GT/CS
Oct 5, 2015 09:43 AM
