My take on the ride height issue...
Ok, this if my first post here, so let me introduce myself. I'm 27, have owned 9 or 10 Mustangs (all of them 5.0s) and I am avid sports car and motorcycle fan.
I sold my cherry 86 GT last year, and I am looking at buying an 05 sometime within the next year. I currently ride a Yamaha V-max motorcycle (the fastest cruiser on the road).
So, back to the original issue, I've given a lot of thought to the ride height issue which has been brought up. I think I might have hit upon the answer...
You will notice similar things about every one of the mules which appears to have smaller tires/too much ground clearance.
a ) the fuel rail on the back of the car
b ) a digital tripmeter on the dash
I believe this signifies the fact that these are, in fact, hybrid vehicles. As such, I wonder if the cars weigh less than normal, and therefore ride higher. I wouldn't think that is the case, as hybrid vehicles generally weigh MORE than simple IC equipped cars. But, they might have put stronger springs on these vehicles in order to carry the extra weight...and the car ended up sitting higher.
Either way, the point is that these are not production 05s, and so there is no need to worry that the ones rolling off the lots will have this ride height issue.
Ok, end of rant.
Ok, end of rant.
Originally posted by scottie1113@June 24, 2004, 11:44 AM
Hybrids? I don't think so, and the ride height looks just fine to me.
http://forums.bradbarnett.net/index.php?showtopic=2722
So, what do YOU think the fuel rail is for then?
Yaa I think there Hybrids. Not all of them though. The ones at shows and stuff most likely are not. Because the hoods are open and stuff. If that was the case. then we would know for sure if they were hybrids because somebody would have posted it after seening the 05 at a show. And the videos we've seen, The mustang sounds pretty beefy ( I love it). and I can't see a hybrid making that kind of noise. But I don't know how Hybrids sound. so correct me if I'm wrong. But yes some of the Mule 05's are most likely hybrid
![Banana](https://themustangsource.com/forums/images/smilies/banana.gif)
Originally posted by ZERO@June 24, 2004, 12:29 PM
those are because it's a test car, right?
Either way, I think that some of the 05 mules are hybrids, and my whole point was that we don't need to worry about the production models looking funky like some of these mules do.
why would they make test mules for a hybrid? shouldnt they be focusing on the mass production gas model V_V .. thats why i think theres no way in heck these mules are hybrids... why waste the time and effort.
Jason
I fully realize I could be wrong about the hybrid thing, but what would be the point of petrol fuel drains?
Also, do you guys in Toronto get new models as soon as the Detroit area dealers do?
1 Post
Those are standard on all test mules, Ford or otherwize. It allows them to check the gas (petrol) at anytime to check for metal shavings, sealant, etc. (its pretty hard to drain a tank without the ports). It also lets them drain it to remove it to check other mecanisms or get a better look at the rear of the car. Ever tried heafting out a half full tank? It also lets them see exact fuel consumption. the gauge on the dash is about as accurate as my dentist. Filling the tank, clocking the mileage, then emptying the tank gives actual consumption and mileage. Many also have quick connect exhaust ports back there to check emissions too. I just finished draining the fuel on a mule for the 2005 subaru legacy turbo here at SIA.
![Canada](https://themustangsource.com/forums/images/smilies/canada.gif)
robjh22
9/8/15 12:31 PM
