My OD off light is blinking constantly
Old May 21, 2012 | 05:27 PM
Started doing it today any ideas why it might be doing that. It also seems to clunk into all gears now. Everything seems tight u joint wise.
Old May 21, 2012 | 09:04 PM
retfr8flyr's Avatar
The OD light blinking is a code for transmission problems. Take the car to a Ford dealer that you trust and they can read the codes. It could be just a solenoid problem or it may be something worse but you need to get it checked out.
Earl
Old May 22, 2012 | 10:47 AM
yea I have been reading it could be any thing from a solinoid to replacing the trans. Crap
Old May 23, 2012 | 05:35 PM
Made an apt for tomorrow morning for a diagnostic test 65 bucks. Pray for me
Old May 24, 2012 | 04:17 PM
sooooo I picked the car up from service and the guy tells me two fault codes come up
pp798 Pressure Control Solenoid "C" Electrical
po791 Intermediate Shaft Speed Sensor "A" Circuit
can't find anything on the net about these codes. Please help lol He tells me it has an internal problem. Daaaaaaaa I could have told him that lol
Old May 24, 2012 | 10:44 PM
antdog's Avatar
pp798 pc solenoid c eletrical
po791 pc solenoid control circuit high
http://www.allfordmustangs.com/forum...odes-dtcs.html
Old May 25, 2012 | 07:35 AM
Thanks Ant! I'm wondering if they will have to pull the trans to get this fixed.
Old May 25, 2012 | 03:04 PM
antdog's Avatar
Considering they get paid by the hour, probably.
Old May 25, 2012 | 07:25 PM
Stoenr's Avatar
Shoulda got a stick
Old May 26, 2012 | 05:25 AM
Originally Posted by Stoenr
Shoulda got a stick
so I could hit you with it??
Old May 26, 2012 | 10:07 AM
Stoenr's Avatar
Haha, good one
Old May 31, 2012 | 11:15 AM
Replaced the solenoid pack 420 bucks for the parts. Total for the whole job 561.00 bucks included filter and fluid. The guy at the trans shop said it was a common problem with the fords. Pretty easy fix, drop the trans pan remove the filter and you will see the sol pack. Remove a few bore bolts remove bad part and reinstall new parts.
Shifts smooth as butter now.
Old May 31, 2012 | 11:31 AM
Old May 31, 2012 | 08:26 PM
antdog's Avatar
Happy for you and your wallet!
Old Jun 6, 2012 | 07:39 PM
naezwoot's Avatar
Just be easy, the car will find its way round the hill when it gets there. hahah
Old Jun 13, 2019 | 02:18 AM
Tommymac's Avatar
The solenoid pack, does that pack contain all of the different solenoids that have have to do with the transmission? What trans shop did you take it to?
Old Jun 13, 2019 | 02:23 AM
Tommymac's Avatar
Old Jun 13, 2019 | 07:22 AM
I am not sure. I believe it is one solenoid. I took it to a well known transmission shop. I forget the name of he place. It was in Orland Park IL
Old Nov 9, 2019 | 06:17 PM
Robert Wells's Avatar
O/D lights flashing on when it get warm and sometimes when I turn off my mustang in restart it stays off 20min. In comes back on help
Old Nov 15, 2019 | 10:52 PM
VistaBlue09's Avatar
You should take it to a reputable transmission shop. You might consider one that’s an ATRA member. The blinking O/D light is like a check engine light for the transmission. You need to have them pull the codes and see what that shows.
RCooke08GT
Feb 19, 2017 03:03 AM
boz
Oct 1, 2015 04:47 PM
mmb0329
Oct 1, 2015 10:59 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
