mobil 1 lawsuit
mobil 1 lawsuit
Went to a couple of auto parts store today they can't buy any mobil 1 they all said because of a lawsuit. Does anyone know whats up? I had to go to 3 stores just to get 6 qts.
![](http://www.mobiloil.com/USA-English/MotorOil/Images/spacer.gif)
Our local Walmarts are much lower on stock than normal, but still have some of most of the varieties in stock in the 5 qt and 1 qt containers. They have jacked up the prices though, presumably because supply is running low.
I stopped using Mobil 1 after a few people discovered Group III basestock in certain Mobil 1 products (which are supposed to use Group IV). I now use Pennzoil Platinum / Quaker State Q Synth which is available all the time at $4/qt. Amway oil is too expensive.
Yep, can't go wrong with Amsoil, good stuff. Not trying to start the "which oil is better" debate, but heck, if you can't find one of them, makes the choice easy.
That situation is in some of the oil that they sell under other names such as the Mobil 1 Clean 5000/7500 Which are just a regular motor oil.
Nope, it was before they played games with the marketing. It should have been a Group IV basestock but they found Group III through GC testing. I just don't see the value in paying more than $4/qt for Group III or Group IV synthetic engine oils considering GM allows up to 8000-9000 miles for semi-synthetic 5W-20 if you follow the oil life "monitor". Audi and BMW specify 10k mile oil change intervals for their synthetic oils (no time was specified). I just change it every year or 6k miles, whichever comes first. Usually the year comes up before I even reach 4000 miles on any of my cars.
Yup, due to the hurricane they got screwed, and were already extremely low on the oil. It just set them back quite a bit. There won't be any available until the beginning of 09, but for now I went to some Royal Purple I found at $6.00 bucks a quart!
All I've ever used in my 97 T-Bird, 4.6, is Motorcraft 5w-30 Semi Synthetic, and a Motorcraft Filter every 3000 miles. I can usually pick up 5 quarts and a filter for less than $15 at Wal Mart. I've never had a problem in almost 100,000 miles, and my T-Bird has almost 175,000 miles on it now too.
No, although some people recommend making your first change after synthetic be sooner than normal because synthetic can clean things out a little. I've changed cars from dino oil to synthetic at all different mileages, from as little as 1000 miles to over 200,000 miles. I've switched at least half a dozen cars to synthetic (Mobil 1) with over 100k miles, including my '89 5.0 Mustang. In every case, if the car leaked or burned oil, the rate of oil consumption went up by a small percentage after I switched. In no case did oil leaks or oil burning start when none existed before.
