Lean codes. Help
Old 12/13/14 | 10:51 AM
greenmachine05's Avatar
Lean codes. Help
So I'm new to forums. But I'm having problems with my car. It's been in and out of shops for two months now. I keep get codes P0171 & P0174, saying it's running lean in bank 1 & bank 2. No one can figure anything out and I don't know what else to do.
Old 12/15/14 | 08:27 AM
Paris MkVI's Avatar
Welcome to the site. Have you done (or had someone else do) any mods to your car? CAI? Anything? Or is she 100% stock?
Old 12/15/14 | 10:04 AM
fuel pressure regulator?? mass air flow sensor, but I would think that has been checked into.
Old 12/15/14 | 11:05 AM
Right - he didn't say what has been checked. Was anything done to the engine just prior to the codes or did they just show up one day driving?
I didn't look up the codes but assuming they are correct - both banks showing lean, then it is weakened fuel flow (or sensor related). How's that fuel filter? Fuel pump failing prematurely? Did they check voltage?
Or something pre-intake manifold (common to both banks) allowing too much air. (So probably isn't O2 sensor going bad or unhooked). MAF needs cleaning, leaking air inlet, new CAI w/o tune?
Old 12/15/14 | 01:15 PM
hOW MANY MILES ARE ON IT?
Old 12/15/14 | 06:46 PM
Yes I have mods. CAI, Magnaflow exhaust (no cats), bbk 62mm throttle body, and bama performance tunes. Had a shop run smoke through intake, fixed a couple vacuum leaks, fuel pressure was ok. Still nothing fixed
Old 12/15/14 | 06:47 PM
Also, I myself replaced downstream O2 sensors, fuel filter, plugs, and tps sensor, before taking it to shops to get looked at.
Old 12/15/14 | 07:56 PM
3point7's Avatar
CAI and a tune, notorious for causing the car to throw a lean code. My guess is the 62 mm throttle body could be a contributing factor as well.
Old 12/15/14 | 08:00 PM
Sounds like time for a dyno tune.
Old 12/15/14 | 08:05 PM
3point7's Avatar
cdynaco is right greenmachine. Let a shop put it on a dyno and adjust your fuel / air parameters while the car is running. You'll get the optimum tune and they can make sure it stays in a safe range across the RPM range.
Old 12/16/14 | 08:26 AM
I've been wanting to get it dyno tuned. But was gonna wait till I had out gears, cams, and headers on it so I could have everything done and wouldn't have to keep going back. Shop it's at keeps talking to a ford tech line and they think it is something with the throttle body. I'm thinking the actuator on it might be bad seeing how it's from the stock throttle body
pats67copo
Repair & Service Help
14
7/19/19 04:45 PM
09-gt/cs
10/15/15 10:03 AM
FromZto5
9/30/15 05:28 AM
dohc97
16
9/24/15 05:40 PM
Smaxon
Which is Better
8/12/15 01:39 PM
Quick Reply: Lean codes. Help
