Leaking Master Cylinder Reservoir
Old Nov 16, 2005 | 03:50 PM
RENEW1's Avatar
Have been reading several threads on leakage around the master cyl. I think the problem is twofold. One, they are overfilling almost to the top, and combine that with a poor fitting cap you get leakage which drips around the reservoir and all over the place. I noticed that the cap has very sloppy fit. In the cap is a rubber diaphram that is supposed to seal to the tank. I find fluid on the cap outside the sealing surface. I made a rubber seal about 1/16' thick, between the cap and the diaphram, and removed some fluid. So far, no leaks. I think it is a hit or miss problem. Some leak,some don't. Just bad engineering or poor production quality control
Old Nov 16, 2005 | 04:02 PM
Fastrack's Avatar
Yep someone already mentioned that, I actually made gasket out of a brake fluid bottle. That sealed it for 3 months, then it started leaking again! I noticed once I remove my gasket, that the cap was VERY loose, so I think the plastic deformed over the 3 months!
Old Nov 16, 2005 | 06:02 PM
Fastrack's Avatar
:( Have been reading several threads on leakage around the master cyl. I think the problem is twofold. One, they are overfilling almost to the top, and combine that with a poor fitting cap you get leakage which drips around the reservoir and all over the place. I noticed that the cap has very sloppy fit. In the cap is a rubber diaphram that is supposed to seal to the tank. I find fluid on the cap outside the sealing surface. I made a rubber seal about 1/16' thick, between the cap and the diaphram, and removed some fluid. So far, no leaks. I think it is a hit or miss problem. Some leak,some don't. Just bad engineering or poor production quality control
Old Nov 17, 2005 | 11:35 AM
Spider's Avatar
Thanks for the heads up guys, I had noticed mine leaking as well....... I'll try to add an extra gasket to mine.....
Old Nov 18, 2005 | 12:32 PM
Jason Dean's Avatar
I noticed mine had fluid on the outside of the reservoir a couple days after I bought it. It had been filled completely full, well above the maximum fill point. I took it back to the dealership and they took some fluid out, and did a pressure test on it and it passed. I haven't noticed any leakage since.
Even a small amount of brake fluid leaking onto a hot engine can be a bad thing, it's flammable. Also, it's corrosive and will eat the paint off of anything it gets on.
(it's a 2006 Mustang GT.)
Old Dec 14, 2005 | 12:47 PM
65205's Avatar
Same problem here.
Just picked up car, They cleaned master cylinder & checked for leaks, none found, gasket OK.
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 23, 2015 03:21 PM
bconboy
Sep 18, 2015 08:18 AM
bconboy
Sep 10, 2015 02:31 PM
