I think my clutch exploded…
Old May 13, 2006 | 10:57 PM
RazorX's Avatar
Angry I think my clutch exploded…
Yeah, that’s right; I said I think it exploded.
I was on my way to get my first dyno run and my car broke before I made it to the shop. I drove 1 ½ hours and was only about 15 minutes from the shop when it happened.
Here’s my story [warning; it is a tad long]…
My buddy and I were driving down the highway in our cars this morning on the way to the shop to do some dyno pulls. Along the way my clutch started feeling a little stiff each time I depressed the pedal. It continued to feel stiffer each time I depressed it but nothing bad enough to make me expect what was about to happen.
Ultimately, I depressed the clutch pedal and tried to downshift into third but it wouldn’t go into gear and made a grinding noise. I didn’t try to force it and waited a second to try again. Same thing so I tried to go back into forth. I couldn’t get it to go into forth either. Now I’m starting to get a little concerned and shifted into fifth (wasn’t easy) and let the clutch back out. It felt extremely stiff when I let the pedal out and I heard something hit the road and bounce up and hit the bottom of the car (kind of like when gravel or something small and hard bounces up and hits the underside of your car).
I tried to push the clutch pedal in after this but it is extremely stiff and the RPM’s didn’t drop at all when the pedal was on the floor. Great!
At this point I’m thinking the linkage broke and fell off. I figured that could explain why it was getting stiffer (as it was loosening/breaking) and the sound of parts falling off.
Miraculously, I actually made it to the shop we were scheduled to get the dyno pulls done at but it wasn’t easy. It was an adventure getting the car into forth gear without a clutch and through one traffic light (thank God that was all) without having to stop.
We jacked the car up to take took a look when I got to the shop. We discovered a hole in the bell housing where something left at a very high rate of speed. The guy that runs the shop (Jeff) said he believes the clutch exploded and blew something out that new hole I have in my bell housing. This wasn’t what I was expecting to find.
I called Ford’s roadside assistance and asked for a flatbed to come get me. They were there in about 20 minutes to take me to the nearest Ford dealership (Eastgate Ford in Dayton, OH).
So I drive 1 ½ hours to do some dyno pulls and see what my car is putting down before doing any big mods and the clutch/transmission breaks...on the highway of all places. I didn’t even get to see what the car is putting down. At least my buddy was able to do his dyno runs. His best pull was 351 rwhp and 361 lb/ft torque on his bone stock ’05 GTO. Thankfully, he was there to give me a ride back home.
At this point I’m wondering how in the world this could have happened and if this will be covered under warranty. My car is very lightly modified and I really do not believe any of my mods could have caused/contributed to this failure but I’m thinking this will be an expensive repair and they may try to say my CAI, non-stock tune, lowered suspension, or the 4.30 gear caused this to happen. The guy that owns the shop I was heading for knows some people in the service department and is working with them to try to ensure they cover this under warranty but he obviously doesn’t have control of the situation.
Sorry for the long post but I’m curious to hear your thoughts on all of this. Any ideas on what could have caused this? What my likelihood of warranty problems will be? Eastgate Ford? Anything else?
Old May 13, 2006 | 11:43 PM
WB2005GT's Avatar
Good Luck
Old May 14, 2006 | 07:17 AM
RazorX's Avatar
Originally Posted by 1SG
Good Luck
Thanks. I may need it.
Old May 14, 2006 | 07:57 AM
94tbird's Avatar
they will blame the gears i can almost ensure it
Old May 14, 2006 | 08:18 AM
RazorX's Avatar
That's my main fear.
Old May 15, 2006 | 08:15 PM
RazorX's Avatar
Well, the diagnosis has been given to me as well as the warranty coverage answer. The call came on my cell phone while I was in a meeting. I left the meeting to take the call once I saw the area code but I didn’t stay on the call for very long because I had left a fairly important meeting and needed to get back to it.
The Diagnosis:
The clutch did explode inside the bell housing just as I feared. The apparent cause of the failure was a spring that let loose and then proceeded to tear the clutch to pieces. It seems that the spring was starting to come undone when I was noticing the pedal stiffening up prior to it completely letting go. The Service tech I spoke with said the only part they needed to replace was the clutch so they ordered one today and he expects it to be in his hands (and hopefully in my car) in a few days. I asked if there was any other damage to the transmission. He said there didn’t appear to be any other damage.
Warranty or out of my pocket?
They are covering it under warranty. I was relieved and stunned at the same time. I honestly believe the guy that owns the shop I was heading to when it happened (Jeff Wightman) had a lot to do with this being covered under warranty. He went over there today and talked to the service manager and the tech. The fact that they know him and trust him probably saved me a boat load of money.
Jeff owns and operates Precision Autosports in Beavercreek (Dayton suburb), OH. He is a stand up guy that does awesome work. He obviously didn’t have to take the time to do this for me but I am very grateful that he did. Heck, I just met him a few weeks ago. He is a class act and I highly recommend him and his shop.
Believe it or not, I forgot to ask about the hole in the bell housing while I was on the phone with the service tech. I can’t believe I didn’t ask him but I was so elated to hear it was being covered under warranty and that I should have my car back by the weekend. I was also pressed for time since I ducked out of a meeting and needed to get back.
Jeff was going to go back over to the dealership and take pictures of the carnage while it was still apart. I will post them when I get them from him.
Old May 16, 2006 | 09:24 PM
RazorX's Avatar
Part 1 of 2
Well the saga continues…
I received a call from the service manager today and he told me he was not going to honor the warranty claim on my car. I explained to him the service technician had called me yesterday and ensured me the repair was going to be covered under warranty. He said he knew that but after giving it some more thought, he decided to reverse that decision. I was stunned.
I asked him why he had decided to not honor the warranty claim on this repair. He said, and I quote, “Well, you have quite a few aftermarket modification on that car.” I asked him if he believed any of the modifications was the direct cause of the clutch failure or contributed to it. He didn’t really give me a straight answer so I asked him “Could you look me strait in the eyes and tell me you honestly believe any of the parts on this car caused or contributed to this failure.” He still didn’t really answer my question directly. Instead he said something to the effect of “When someone puts parts like that on a car, you have to assume they are not driving it the way it was intended…they are abusing the car…drag racing…etc.” I paraphrased his statements back to him and asked if I understood him correctly and he agreed that I had and mentioned something about hard launching the car (i.e. drag racing).
I told him that I didn’t believe any of the aftermarket parts I have on my car would have contributed to the failure of the clutch and that I didn’t agree with the principle of him deciding to refuse the warranty claim based on an assumption about the driving habits of the owner that was construed from the presence of aftermarket parts. I went on to explain that I have never had the car to a race track nor had I ever engaged in street racing in this car. I explained that I spent a lot of time researching parts and was very selective in what parts I installed because (a) I wanted to tailor the cars handling characteristics and power delivery to my personal taste and (b) because I wanted to make sure I didn’t install something on the car that would create the exact situation I am now in. He said he could understand my points and that he hated to make assumptions because it…
Here are some of the things he mentioned regarding my parts and my responses:
Suspension
Service Manager (SM): It looks like you have some suspension components installed…lighter weight springs in the back…brace…
Me: That is correct. In addition to the springs (front and rear) I also have adjustable shocks and struts installed as well as an adjustable panhard rod to re-center the rear axle after lowering. I also have stronger bracing to reduce deflection in the areas the stock components are known for having shortcomings. All of the suspension components installed on this car improve the handling characteristics without sacrificing the stock ride. The lower stance also makes the car look much better which I desired. None of these would contribute to a clutch failure nor would they be especially desirable for a drag racing setup since they change the pinion angle. That hurts your ability to launch as well. I would have went with a completely different suspension setup had I intended to drag race this car.
Tires
SM: You also have some pretty big tires on there. I assume those would give you much better traction (I assumed he was implying drag racing again).
Me: Yes they do…for cornering. I restated this car is setup to handle better without sacrificing the stock ride and that I wouldn’t be running this tire/wheel combination if my goal was drag racing the car. I would be running drag radials out back and much skinnier tires up front on smaller diameter wheels.
Gear
SM: It looks like you have a different gear installed in it too.
Me: Yes, I do have a lower gear installed.
SM: What is it a 4.10?
Me: No, it is actually a 4.30.
SM: Wow! That’s an even bigger gear than I guessed.
Me: Do you know why I selected that gear and/or why I want it in this car?
SM: Why?
Me: Because I drive the car around town, to work, and occasionally on longer highway trips. This gear ratio keeps me in the power band and allows for quicker acceleration without requiring downshifts as much. Kind of ironic that I was downshifting when the clutch went out in this car.
SM: He chuckled and said “yeah it is.”
I also told him what the service tech had told me about the apparent cause of the failure (the spring coming off and binding up the clutch) and also reiterated what I was doing when the part failed (downshifting into third gear while driving on the highway). I asked him how he thought that action could be construed as abusive or inappropriate driving. He said while that wouldn’t be, he couldn’t be sure I was telling the truth.
I even asked him if there was a data logger on this car and/or if he could extract the data from the “black box” to see what was going on with the car when the clutch broke and that I thought this information would prove I was telling him the truth. He said “Unfortunately, there isn’t anything like that on these cars. I asked our service techs that same question because the Dodges have that and they informed me these do not.” I told him that was a shame considering he was basing his decision on an assumption that I felt this data could prove to be wrong.
After all of this conversation he admitted that his main concern was that Ford would deny the claim when they sent the part back for inspection and the dealership would be out of the money for the parts and labor.
He said he could understand my position and asked if I could try to see his. He said he has an obligation to the dealership to make sure they don’t eat the money on this warranty claim. I told him I was trying real hard but was struggling with that request. I told him it was a very tough and bitter pill to swallow considering we both agree at this point that none of these parts would cause this failure and I know I wasn’t abusing the car. I also told him I feel he has an obligation to the customer when representing Ford just as much as he has one to the dealership.
He then told me he had two options for me:
  1. I could buy an aftermarket, higher performance, clutch and they would install it for the cost of labor (about three – three and one half hours). He even said they looked and thought I could get one from Jegs for about $200. He also said “I obviously wouldn’t be able to cover it under warranty since it would be an after market part.”
  2. They could go ahead and install the factory replacement clutch that they had already ordered, charge me for the parts and labor, submit it as a warranty claim, and then refund me the money if Ford accepts it. He said I would obviously have to trust him to refund the money if it was accepted.
I told him neither of these options sounded fair or just considering everything we just discussed. I also told him it apparently didn’t matter which of these option I chose from a warranty coverage perspective since he was denying the claim on this stock clutch right now. His response was that he had given this a great deal of thought (and even lost sleep over it last night) and this was the best he could do.
He said I didn’t have to give him the answer right now but could think it over and get back to him. I asked him what the total cost of each option would be and he said that he hadn’t ran the numbers yet. I told him that I would obviously need that information before I could even consider the options and he agreed to call me back with the complete cost of each option.
He called me back about five hours later with the numbers. He said the total cost to do option 2 would be $750 ($325 in parts & $425 in labor). I asked him if he had reconsidered and he said no, this was the best he could do. He said he would cut me a check the moment Ford accepted the warranty claim but I would have to have my money tied up until then. I told him I would think about it and talk to him tomorrow.
Old May 16, 2006 | 09:25 PM
RazorX's Avatar
Part 2 of 2
I have given this a fair amount of thought and I really do not feel this is fair or justified. We both agree that none of the parts on this car would cause a clutch failure. I am certain I haven’t abused the clutch. I have driven the car like a performance car but nothing that would be considered abusive.
The more I think about it the more I am shocked that he would even suggest option one considering the big production he made about the parts on my car now let alone that he would even mention that he wouldn’t be able to cover the aftermarket clutch under warranty.
I feel like I am in a bit of a tough spot with this one. I don’t want to take either of these options; almost on principle alone (the money does play some part in it too though). I also don’t like the idea of having the car towed (likely at my own expense) to another dealership and possibly going through the same hassle again or worse.
This is what I plan to do:
  1. Contact the dealer I purchased the car from (and possibly a few others), explain the situation to them and see what they say.
  2. Check the price on a Spec Stage 2 clutch kit and aluminum flywheel (The best deal I have found so far is at Brenspeed).
  3. Check with Jeff to see what he would charge to install the Spec Stage 2 clutch kit and aluminum flywheel.
  4. Call the service manager back, explain that I have given this a lot of thought (and even lost some sleep last night), that neither of these options are fair or acceptable and ask him to reconsider.
  5. Depending on his response to my request, I will either have them complete the work under warranty like they originally said they would or ask him to please put the car back together and I will come to pick it up.
I will either have it towed to another dealership to have them do the work under warranty or take it to Precision to have Jeff perform the work (install either the Spec parts or stock parts). This will depend on what my the other dealerships say about covering it under warranty.
Old May 16, 2006 | 09:30 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Razor, are you on any other Mustang Forums???
He's obviously not 100% informed as to the EDR's and other computers on these cars: From the manual -
Service Data Recording
Service data recorders in your vehicle are capable of collecting and
storing diagnostic information about your vehicle. This potentially
includes information about the performance or status of various systems
and modules in the vehicle, such as engine, throttle, steering or brake
systems. In order to properly diagnose and service your vehicle, Ford
Motor Company, Ford of Canada, and service and repair facilities may
access vehicle diagnostic information through a direct connection to your
vehicle when diagnosing or servicing your vehicle.
Event Data Recording
Other modules in your vehicle — event data recorders — are capable of
collecting and storing data during a crash or near crash event. The
recorded information may assist in the investigation of such an event.
The modules may record information about both the vehicle and the
occupants, potentially including information such as:
• how various systems in your vehicle were operating;
• whether or not the driver and passenger seatbelts were buckled;
Introduction
• how far (if at all) the driver was depressing the accelerator and/or the
brake pedal;
• how fast the vehicle was traveling; and
• where the driver was positioning the steering wheel.
To access this information, special equipment must be directly connected
to the recording modules. Ford Motor Company and Ford of Canada do
not access event data recorder information without obtaining consent,
unless pursuant to court order or where required by law enforcement,
other government authorities or other third parties acting with lawful
authority. Other parties may seek to access the information
independently of Ford Motor Company and Ford of Canada.
MIDDLE EAST/NORTH AFRICA VEHICLE SPECIFIC INFORMATION
For your particular global region, your vehicle may be equipped with
features and options that are different from the ones that are described
in this Owner’s Guide; therefore, a supplement has been supplied that
complements this book. By referring to the pages in the provided
supplement, you can properly identify those features, recommendations
and specifications that are unique to your vehicle. Refer to this
Owner’s Guide for all other required information and warnings.
Introduction
Old May 16, 2006 | 09:55 PM
RazorX's Avatar
Yeah. I originally posted this on a total of nine Mustang Forums to solicit information from as many people as possible and then to let everyone that read/replied up to date on the developments.
Thanks again for this information. I will see if it can help me in any way.
Old May 17, 2006 | 09:02 PM
97svtgoin05gt's Avatar
Is there a reason you wouldn't immediately contact Ford customer relations FROM THE DEALERSHIP when you were told no? I really think I'd have driven there and held an inpromptu con call with the dealer knucklehead and Ford service relations. The clutch simply went bad. Has happened before, will happen again. They should at very LEAST cover you on the first offense. If you were to come back again with the exact same issue, well then okay. No warranty at that point.
Once again, the Blue Oval service department proves their BS approach and attitude.
BMW would've changed the clutch, washed your car and thanked you all while giving you cookies and coffee while you waited.
Old May 18, 2006 | 05:25 AM
RazorX's Avatar
I wasn't at the dealership when I was told no. I was talking to the SM on the phone while I was at work. I would have loved to drive down and discuss it in person but the dealership is 1.5 hours from my house and it isn't that easy for me to take impromtu time off from my job.
Old Jun 11, 2006 | 10:47 AM
incomingRPG's Avatar
A few weeks have gone by now, how about an update? Hope it turned out in your favor.
Old Jun 11, 2006 | 11:18 AM
burningman's Avatar
Bow Chica Bow Wow
TMS Staff
Yup once again ford screws another customer. Been there done that a dozen times. Hope you get this resolved to your satisfaction..I'll tell you the more I read your story the more I was hoping you were going to say that you just decked him in his own office. I'd probably have been in jail for murder at that point.
Good luck mate!
Too bad you didn't record the conversion then just run it over to a lawyer and see if they could help.
Old Jun 11, 2006 | 12:00 PM
Tony Alonso's Avatar
There was an article I was reading in a recent MM&FF regarding this scenario. One of the suggestions was to take the vehicle to an independetn repair shop and have them document in writing their observations and reasons for the failure. If you chose to go to through the arbitration process or the lawsuit route, you would have information to back up the claim the failure was not related to your modifications.
Good luck and let us know what's happening.
Old Jun 19, 2006 | 10:02 AM
Enfynet's Avatar
... My clutch exploded yesterday. Only instead of being able to put the car is gear it wouldn't catch on anything. I got on the highway and it started slipping really badly. I tried to downshift to 3rd where it felt like it was grabbing a little as I was changing lanes to merge onto I-96 east from western Detroit, the car almost immediately redlined and I heard a bang under the car.
Apparently my mom had thought it sounded funny when she shifted it anytime she drove it. Unfortunately I wouldn't know as this is the only manual trans car I've ever driven. On top of that I'm almost 200 miles from where I live and AAA could only tow me 100 for free. So I had it put in front of Blackwell Ford in Plymouth, MI until this morning when I could get a ride to the dealership. No warranty coverage but he said I should have my dealer at home contact ford to see if they could reimburse me. At 26k he thought it was an early failure as well but being a wear part they can't warranty it.
Old Jun 19, 2006 | 11:33 AM
bob's Avatar
bob
Razor was it a spring in the clutch hub that failed or the fingers on the diagphram?
Enfynet, that seems wierd, don't the 05's come with a 30k powertain warranty?
IMO, you guys are getting jerked around! Warranty repairs don't pay crap to the dealer so they are loathe to repair items under warranty.
Old Jun 19, 2006 | 12:46 PM
Enfynet's Avatar
Yeah, that's what I thought but I'm going to write a letter to Ford when I get back home because this seems a lot early for something like this to be happening.
Old Jun 20, 2006 | 09:16 PM
stangster's Avatar
"When someone puts parts like that on a car, you have to assume they are not driving it the way it was intended…they are abusing the car…drag racing…etc.”
So tell him to prove it. Your warranty shouldn't be dependent on his "opinions" which are going to be heavily colored by his desire to make money. Furthermore, if he is going to deny it your claim, he is going to need more proof than his "educated" guess.
Old Jun 21, 2006 | 11:20 AM
Boomer's Avatar
I can understand a completely burned clutch based on driving habits not being covered, or being questioned.....
but an exploded clutch that early...
uh..yeah..not right.
Gill5oh
Oct 6, 2017 10:50 PM
Sep 23, 2015 03:21 PM
JonathonK
Sep 19, 2015 03:19 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
