I blew a fuse on the central console
Old 7/10/11 | 01:17 AM
Mr.freezey's Avatar
Anyone have any Idea where that fuse is and which one to replace thanks
Old 7/15/11 | 07:08 PM
Lime GT's Avatar
You should try to be just a little more specific as in what isn't working now; lights, cig/12v outlet, radio, etc.
Old 7/20/11 | 05:23 AM
Mr.freezey's Avatar
The 12v part everything else works fine
Old 7/27/11 | 02:20 AM
Aamador521's Avatar
you probably already fixed it but it's next to the passenger side foot panel. take that panel piece off and it's the plastic piece. it's probably one of the 10 ones. i've blown several fuses thanks to some grounding problems. if not check the fuse box under the hood. it's on the passenger's side too. just get some needle nose pliers and start pulling out all the lower rated fuses and see which popped. then put them back right away. but I would look at the manual first. check the obvious places first.
actually i think the 12v is under the hood. but i'm not 100% sure.
Old 8/4/11 | 01:42 AM
Mr.freezey's Avatar
Thank you for your help
Old 8/4/11 | 03:13 AM
11SHELBYGT500's Avatar
Under hood location 64
papayote
Ecoboost
2/21/17 11:16 PM
Fedupdave42169
10/23/15 09:58 AM
tang65c
10/6/15 07:39 PM
tbear853
9/8/15 11:18 PM
johno29
8/24/15 01:09 PM
Quick Reply: I blew a fuse on the central console
