Hydraulic Clutch on V6 / GT ?
Hello. The other day, a co-worker was claiming that if only Ford would have used a hydraulic clutch instead of the stiff cable one on the 05's, he may have purchased the car.
I claimed that I believed they were hydraulic clutches, but I can't find proof anywhere on the site. Can anyone direct me to a fact sheet or confirm the clutches are hydraulic on the 05+ GT and V6 manuals? Thanks.
From the workshop manual:
"The clutch operating mechanism consists of the following components:
Flywheel
Clutch disc
Clutch pressure plate
Clutch release bearing
Clutch master cylinder
Clutch slave cylinder
The clutch master cylinder transmits fluid pressure to the clutch slave cylinder, which in turn moves the clutch release bearing. The clutch hydraulic system uses brake fluid and shares a reservoir with the brake system."
Flywheel
Clutch disc
http://bradbarnett.net/mustangs/timeline/0...ODUCT_GUIDE.PDF
Drive it and you can tell right of way. I finally got to drive a GT stick last weekend and confirmed that I am glad I ordered the slushbox. The hydraulic clutch provides very little feedback as compared to the older mechanical setup. I could never feel the clutch engage. It was almost a suprise every time we moved out at a light. Reminded me of my 1990 Miata.
Heh you should drive one with a tune.
9/23/15 03:21 PM
JonathonK
9/19/15 03:19 AM
