High Temp paint for plastics?
Old Apr 23, 2006 | 05:06 PM
StangNut's Avatar
I have a used Airaid CAI and it looks... used.
I'd like to paint it, but it gets pretty hot under the hood. Are there any special paints out there I should use or any special prep work?
Would regular plastic paint work?
Old Apr 23, 2006 | 05:12 PM
wyldv6's Avatar
Use the spray paint meant for barbque grills, comes in your choice of colors too, as long as its black.
Old Apr 23, 2006 | 05:41 PM
StangNut's Avatar
Black's fine, but how well does that stick to plastic?
Old Apr 23, 2006 | 05:59 PM
korinwoodo's Avatar
Ive used auto paint one plastic, just put a coat or two of primer on first. You could try the Krylon Fusion stuff. It works really well on plastic.
wyldv6's Avatar
Try the "Krylon Fusion" paint as a primer, this sticks to plastic , then spray on the heat paint. Krylon makes some of this as well, not sure what colors though.
Old Apr 23, 2006 | 07:38 PM
scotts05custom's Avatar
what scrming use to paint his pulley cover or whatever?
Old Apr 26, 2006 | 01:27 PM
Badsnke98's Avatar
Use the Plastic Adhesion Primer by Dupli-Color and any wheel or engine paint color that works for you. The engine bay only gets upto around 190 at the engine and the air intake is not hottest babe in the room by far.
Old Apr 27, 2006 | 02:23 PM
StangNut's Avatar
Thanks, Bruce.
Old Jun 11, 2006 | 03:14 PM
Mongoose's Avatar
Think about this. If its hot enough to melt the paint it will melt the plastic also.
May 3, 2026 05:42 AM
Cobiecane
Oct 23, 2015 08:44 AM
GLOCKer
Sep 28, 2015 05:20 PM
