High Temp Paint
Old Jun 18, 2005 | 03:13 PM
rrobello's Avatar
TMS West Coast Correspondent
Does anyone know where to get a good selection of high temp paints? I want to paint my valve covers but I want something more than just the simple normal selection of blue, red, black, ect. I am actually really looking for a dark charcoal color and hopefully even one with a pearl if possible.
Another question for those in the know....would it be safe to do it with a high temp primer, then a normal body paint and coated with a high temp clear coat, or will that still eventually crack?
Thank you in advance.
Old Jun 18, 2005 | 03:44 PM
Mr. 'Stangster's Avatar
All coats have to be high temp. What about powder coating ? It's high temp as its baked on and nearly bullet-proof.
Old Jun 18, 2005 | 03:51 PM
rrobello's Avatar
I thought about that but I was going to do it myself if possible and I dot have the stuff to powder coat so I would have to go somewhere to do it, but I was thinking about buying powder coating equipment....anyone know the difficulty level of powder coating, more, less or about the same as painting?
Old Jun 18, 2005 | 03:55 PM
WERKED 66's Avatar
here check out this site....
eastwood
Old Jun 18, 2005 | 03:57 PM
rrobello's Avatar
thanks thats the one I was thinking about
Old Jun 18, 2005 | 03:59 PM
WERKED 66's Avatar
no problem
Old Jun 18, 2005 | 08:39 PM
Badsnke98's Avatar
I truely think you could side with primer and clear being High Temps. I only use regular primer at times and find no problems.
Old Jun 18, 2005 | 09:23 PM
Clear will crack/craze at normal underhood temps. It would only look good for a short while.
Old Jun 19, 2005 | 02:39 AM
rrobello's Avatar
err I might have to go with the powder coating option....anyone know of a good place in SD or SoCal for that matter?
Old Jun 19, 2005 | 06:07 AM
WERKED 66's Avatar
why not do it yourself... plus if you want to do more then just the cover you have the kit....
Old Jun 19, 2005 | 06:14 AM
Badsnke98's Avatar
I have no problems with High Temp Clear! No cracks in my Cobra three years. The Ceramic in the paint is rated for 500 degrees and most likely good for a bit more. The Engine Bay only goes to 185 degrees in a few select areas and averages around 150 within just 2 or 3 inches of the engine. This is on an average 72 degree day. You still have plenty of room for the 100 plus desert sun.
[attachmentid=24950]
Once you do Ceramic Coating, the color cannot be changed. So be very sure you like your color choice
Old Jun 19, 2005 | 09:37 AM
burningman's Avatar
Bow Chica Bow Wow
TMS Staff
just goto autozone and buy the VHT 1200 degree stuff. I've painted who engines with this stuff over the years and never ever had an issue.
Old Jun 19, 2005 | 10:11 AM
rrobello's Avatar
color choices stink at the local shops, been to Pepboys, AutoZone, Kragen, NAPA, and HomeDepot, nothing but maybe 5 choices in High Temp Paints
Badsnke...where did you get your paint, that loooks awesome, is it the mystichrome paint that is a three step spray can process? If so how did you keep it from cracking, isnt it just normal body paint?
Old Jun 19, 2005 | 08:22 PM
Badsnke98's Avatar
Dupli-Color paints, Grey Filler Primmer, High Performance Wheel Coating (Highly reflective metallic) for the base. Then useing a light wind blown splattering of (from your local hobby store) Colors by BOYD, I used Kandy Purple Pearl and True Blue Pearl. Follow with 3 coats of Dupli-Color High Temp Engine Clear.
If you get to heavy with your colors in some areas, which will happen, just use a light spray of the wheel coating base to blend things together. All three colors will highlight depending on suns angle. Try smaller parts first to get the feel of it.
It's not going to crack. Just do not let any wiring harness vibrate on it.
May 3, 2026 05:42 AM
Cobiecane
Oct 23, 2015 08:44 AM
GLOCKer
Sep 28, 2015 05:20 PM
