High Idle - Please help guys.
Old Aug 3, 2010 | 01:47 PM
GAGT's Avatar
The past two or three weeks when I have got into my car after work the car idles at 2500 - 3000 rpms for about 5 - 7 minutes and then it goes back to normal idle. I have checked the trouble codes and it doesn't have any. Does anyone have any idea of what could be causing this and how to fix it?
Old Aug 3, 2010 | 02:02 PM
sams66's Avatar
I just put a throttle position sensor on my car because of it pulling codes and going into failsafe mode quite a bit. if you have a stock TPS sensor that may be the cause, because I read that irratic idle quality is also a factor if your TPS sensor is bad.
Sam
Old Aug 3, 2010 | 05:02 PM
antdog's Avatar
Clean your throttle body.
https://themustangsource.com/f669/br...e-body-481491/
Old Aug 3, 2010 | 08:14 PM
houtex's Avatar
And reset the computer and throttle pedal. That thread now has those instructions. Mine required retraining from scratch after the cleaning.
Old Aug 4, 2010 | 02:18 AM
tom_vilsack's Avatar
have you tryed using seafoam?
i seafoamed my fox,and was like whole new car afterwards...i used can into vacuum method...but they also make spray to clean throttle body...
Old Aug 4, 2010 | 06:10 AM
GAGT's Avatar
I'm going to clean my throttle body and reset my pedal this weekend. I hope it helps!
May 3, 2026 05:42 AM
oneeyedgiant
Sep 29, 2015 01:33 PM
