HID KIT INSTALL HELP!!! 2005 Mustang GT
Old Sep 12, 2008 | 05:16 PM
cdown16's Avatar
Hey, someone please help me with my HID install kit. I have tried everything and cannot get these things to work! I purchased the kit from MrBodyKits.com or StealthAuto. It is just the H13 single beam kit. I will post pics if needed, just let me know. Any videos or pictures would be helpful! Thanks for everyones help in advance!!!
Casey
Old Sep 12, 2008 | 05:50 PM
08VistablueGT's Avatar
Definitely post pictures. It's a fairly simple install.
Are your balasts properly grounded and hooked up? An incorrect ground could easily make them not function.
--Brandon
Old Sep 12, 2008 | 07:23 PM
TNumber5's Avatar
That happened to me. I could only get one of mine to work then I noticed I had a bad ground on one side.
Old Sep 12, 2008 | 07:31 PM
Yup. What is tough in the engine bay is that all of it is painted. Even when your ground is touching bare metal (that is painted) you might not have a solid ground. I would rule this out first with your HID problem. Take an aggressive grit sand paper and sand away some of the paint on the grounding location, re-ground the wire, and see if that works. If not, it's ok, just part of process of elimination.
Old Sep 12, 2008 | 08:24 PM
cdown16's Avatar
Pics...
Old Sep 12, 2008 | 08:27 PM
cdown16's Avatar
I know I sound rediculous but what wire is a ground wire? I called the company and they said nothing about a ground????
Old Sep 12, 2008 | 09:45 PM
Deric's Avatar
I don't have the brand you have but is the black and red wire twisted together on your second pic? I would assume that is power and ground. You should be able to run the red wire to the fuse box (where the battery cable connects) and the black should go on a chassis ground. I used an existing ground point for mine.
Everything else was plug and play.
Old Sep 13, 2008 | 09:27 AM
cdown16's Avatar
The red and black wire with the single prongs are not twisted together, they are separate. They are not very long so how do I go about making the red one reach a power source? The fuse box and battery are obviously on the passenger side so how do I make the driver's side light reach with a 1 foot wire?
Old Sep 13, 2008 | 10:54 AM
v6tungsten's Avatar
From the pictures it looks like PIC1 connects to you headlight plug, picture3 connects to the outlet of pic1. pic2 plug into the pic3 red and blue.
Originally Posted by cdown16
Pics...
Old Sep 15, 2008 | 10:42 PM
Deric's Avatar
This should help it's the same type of slim ballast install.
http://www.benzworld.org/forums/w202...t-install.html
Old Sep 16, 2008 | 01:28 AM
StangRalle's Avatar
Once you get it working. Let us know how you like it in comparison to the stock setup.
Old Sep 21, 2008 | 10:03 AM
Deric's Avatar
Did you ever get it working?
Old Sep 21, 2008 | 10:14 AM
cdown16's Avatar
yes I did. I highly recommend this kit from mrbodykitz. It is plug and play, no grounding or anything required and these lights look amazing at night. I got the 8000k color and they are bright! Thanks for everyones help!
Old Sep 21, 2008 | 12:34 PM
tom281's Avatar
If its all plug and play then why did you have trouble installing it LOL......
OK seriously though, congrats.... glad you got it working and are happy.
Old Sep 23, 2008 | 07:53 PM
topbliss's Avatar
what was wrong???
Old Sep 24, 2008 | 06:49 AM
metroplex's Avatar
I've never done a HID install on a Stang, but the concept is the same for all 12V ballasts:
You feed the ballast +12 VDC from your low beam supply with a relay setup. Essentially your current headlight low beam + GND feed now controls the relay which switches +12 VDC from your battery directly to the ballast. The ballast wires then connect to the HID capsule. Your high-beam is either disabled or actuates a solenoid that controls the shutter or moves the capsule up/back to act as a high beam.
Old Jun 4, 2016 | 10:40 PM
Doc_garrett's Avatar
hey I have the same problem with my short wires what do I do with them??
Old Jun 6, 2016 | 09:47 AM
07 Boss's Avatar
??? Make them longer?
Old Jun 7, 2016 | 01:42 PM
kd4gij's Avatar
So many people blinding on coming traffic.
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
Ecostang
Nov 3, 2022 08:50 PM
AMWill
Jul 20, 2015 08:40 AM
