Heater Output
Originally posted by Lime GT@December 10, 2005, 8:02 PM
Rupert, good to see someones had the install done.
Actually, I have seen a few people install them. I posted a thread last year about my install. I had mine put in by the dealer when th e car arrived. They put the switches on the side of the seats. It does feel real good. I use them in the summer sometime when my back tired.
Originally posted by adrenalin@December 3, 2005, 12:07 PM
I never understood why when I choose the floor setting heat still comes out of the defroster vent on the dash. Good idea, poorly executed.
Originally posted by Tiberius1701@December 1, 2005, 8:03 AM
Mine also provides very hot temps, but the amount routed to the floor seems to be less than it should.
I have checked with engineering and there are no known issues, go figure.
ds
<div class='quotetop'>QUOTE(Tiberius1701 @ December 1, 2005, 6:03 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I took mine in with the same issue and the heater hose was loose and not connected... they hooked her back up and its now a lot better...
[/b][/quote]
legacy Tms Member
I found that by just selecting 'floor+dash', and closing the dash vents I can drive in the winter without freezing my feet or the kids in the bachseat...otherwise 'heat' only hits driver/passenger in the face. I ordered a dvd service manual, should be here today or tomorrow- hopefully schematics are complete, and I AM going to make some changes to shut that friggin defroster. floor+ dash works, but if fan over '3' it whistles, and warms the rear too slow(floor vents seem to blow under seat to rear a bit too).
<div class='quotetop'>QUOTE(ford4v429 @ February 20, 2006, 5:27 PM) Quoted post</div><div class='quotemain'>
...hopefully schematics are complete...[/b][/quote]
hahaha. That's funny... not even the schematics that Ford uses are complete. haha.
The heat output is OK but I like the relative vent locations in the 95 a lot better. If you are riding top down in marginal weather, the heat does not help a whole lot. If the vents were located better, It would make a big difference.
Mine seems to be the same way.
I don't think it's the temp of the engine or air blowing out the vents. I believe it's that lack of volume that gives the effect of poor heating. Seems like it's choked off.
When it's on floor it seems like there's isn't a lot of air coming out the vents. Lots blowing up top too, glad to see it's 'normal'.
legacy Tms Member
<div class='quotetop'>QUOTE(jfrayzier @ February 20, 2006, 4:30 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
yes...not complete- however it does show the wiring well enough that adding some resistors(maybe a dual pot that could be hidden yet adjustable to figure out resistor sizes needed) should be able to pretty easily 'recalibrate' endpoints/mid(blend)point...will let you know what happens.
(poof?)
[/b][/quote]
(poof?)
<div class='quotetop'>QUOTE(ford4v429 @ February 24, 2006, 5:33 PM) Quoted post</div><div class='quotemain'>(poof?)
[/b][/quote]
I don't really want to go into it again, because it gets me all depressed.. but I looked at scematics to determine if I could install a factory option on my vehicle. It looked like I could, the parts department determined that I could, Ford's technical engineers determined that I could.. but when I went to add the part, some of the wiring was missing in my vehicle.
Ford said that since I didn't need it for the options that weren't included originally with the car, they decided not to put the rest of the wiring in the car.
[/b][/quote]
legacy Tms Member
<div class='quotetop'>QUOTE(jfrayzier @ February 24, 2006, 4:39 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
yeah- theres got to be some various harnesses for side airbags/IUP/shaker 1000...this blend issue looks like it should be fairly easy to 'fool' though- just need to shut off the car or unplug the blend motors in each of the three positions, and grab an ohm reading at each, tweak whatever needs tweaked by adding a pot to shift blend without exceeding end of travel, read the 'ok' setting on the pot and add a resistor or three as needed...wish the inner circuit of the climate control module were available- thats where the problem lies I think, unless door servos used very wide tolerance resistors which I kinda doubt.
[/b][/quote]
<div class='quotetop'>QUOTE(EleanorsMine @ December 1, 2005, 6:58 AM) Quoted post</div><div class='quotemain'>
Mine will burn you out of the car.
[/b][/quote]
Ditto
[/b][/quote]
Ditto
[/b][/quote]
Mine too, it'll roast ya [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
[/b][/quote]
<div class='quotetop'>QUOTE(EleanorsMine @ December 1, 2005, 3:58 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Was it born in Hades ? kidding Mine is the same, so when engine Hot in our climate I leave it right in the middle or off 80 % of the time and all ports work the way they should to direct the flow [img]style_emoticons/<#EMO_DIR#>/04.gif[/img]
[/b][/quote]
