Headlight help
Headlight help
I installed HID's about a year and a half ago and now all of a sudden, when I hit the unlock on the remote both head lights come on. When I get in the car and start the car and manually turn the headlights on, the passenger side doesn't fire up. I have to turn the car off and restart it for the passenger light to come on.
Any ideas what could be causing this?
Try swapping the hid bulbs to the opposite side and see if the problem moves with that bulb to the other side. If so, probably your bulb. If not it could be a bad ballast or bad ground. HIDs are sensitive about good ground connections. But I'm thinking it's the bulbs. I had a similar problem with my fog lights
Former Vendor
Feel free to call us if you need help troubleshooting: (314) 205-3033
Even if it's not our kit, we have a lot of experience and will try to get your current kit working again.
I suggest checking your connections for corrosion and installing an HID relay if you haven't already
Thanks!
Nick C.
Thanks!
Nick C.
