Hard to close driver door
Old Nov 24, 2006 | 06:47 PM
metroplex's Avatar
Has anyone run into any door(s) on 05-up Mustangs that are hard to close? I have to basically slam the door to get it to close on the first try. Usually I lube the hinges with ATF but before I do that on the Stang, I would like to know if anyone has found a better solution.
Old Nov 24, 2006 | 07:36 PM
my 06 passengers door takes a little more effort than it should.
Old Nov 24, 2006 | 07:39 PM
jadeuel's Avatar
Is your window down/up thing working properly. When you open the door is the window dropping that 1/2" or whatever it is and then going into the seal when it is closed.
Old Nov 24, 2006 | 08:01 PM
metroplex's Avatar
Yes, the automatic window thing works properly. The problem is the door does not close very easily. I literally have to slam my door to get it to close and I do not like doing that to my cars. My 00 Crown Vic's doors close with a gentle touch. If I can't find an easy solution, I will just drop some ATF into the hinge rollers and maybe apply some extra grease in the striker latch.
Old Nov 24, 2006 | 08:05 PM
LEO_06GT's Avatar
Sounds like somebody needs to go to the gym.
Old Nov 24, 2006 | 08:09 PM
metroplex's Avatar
LOL!
I remember a Bold Moves Episode where Mark Fields closes the door on a Toyota. He does a double take and opens the door and recloses it. The look on his face is sheer bewilderment. I'm assuming he's shocked at how easy it was to close the door on the Toyota. I can slam my driver side door shut if I close the door like I hate the car. I even went as far as "riding" the door shut by closing the door using the handle. Unless I apply a lot of force, the door does not shut properly and I don't feel it is "right". It should close very easily and on its own weight if given the correct amount of initial force.
Old Nov 24, 2006 | 08:18 PM
LEO_06GT's Avatar
Originally Posted by metroplex
LOL!
I'd say taken in for warranty service.
Old Nov 24, 2006 | 08:27 PM
Rapture's Avatar
I think the Doors are heavy vs others (my explorer), need s alil effort, Oh I hate when people slam my doors ( any car) My Explorer and T-bird close with lil effort, but people always slam them
Old Nov 25, 2006 | 06:48 AM
metroplex's Avatar
I noticed that it was the window preventing the door from closing normally. The window (when rolled up) tends to hit the seal and slow down the door. If I roll down the window, the door closes VERY easily (on its own weight, etc...) It doesn't seem to be a lube issue after all.
Old Nov 25, 2006 | 08:30 AM
Zig-Zag's Avatar
I say take it in. Mine closes like that Toyota.
Old Nov 25, 2006 | 05:26 PM
jadeuel's Avatar
It does tell in the owners manual how to adjust the auto up / down feature properly.
Old Nov 25, 2006 | 05:49 PM
metroplex's Avatar
jadeuel: Thanks! I will recalibrate them asap. For those tuning in, its page 52 in the 07 manual.
Old Nov 26, 2006 | 09:15 AM
metroplex's Avatar
Update: Recalibrating the windows didn't help. I recall that the driver's door on a convertible GT/CS at the dealership had the same problem.
Old Nov 26, 2006 | 09:48 AM
jadeuel's Avatar
Bummer...thought it might help. When I had my battery out for Valve cover painting I recall opening and closing the door and having difficulty due to no power to the windows. Hope you can find the fix.
Old Nov 26, 2006 | 10:37 AM
RaGsHoCkEy88's Avatar
i had that problem yesterday for like 15 minutes. then it starts working again....
Old Nov 26, 2006 | 07:06 PM
Little Black Pony's Avatar
Is the problem that the door isn't latching properly, or that it takes excessive force to get the door to swing shut?
My doors shut fine with just a little push. Usually just two fingers will do.
Old Nov 26, 2006 | 07:33 PM
metroplex's Avatar
The window seems to push against the seal which causes it to slow down enough to not latch properly. With the window rolled down a bit, the door closes just fine.
Old Nov 27, 2006 | 01:41 AM
Giddyup's Avatar
Do you know right off hand if the 'how to' of calibrating the windows is in the 05 manual as well?
Old Nov 27, 2006 | 02:54 AM
metroplex's Avatar
It should be in there since 05-up GTs have the same window feature (short drop when door is opened).
Old Nov 27, 2006 | 04:53 AM
jadeuel's Avatar
See page 46 of the 2005 Owners Guide.
JonsMustang
Mar 5, 2016 05:44 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
Sep 8, 2015 10:45 AM
jim010
Sep 7, 2015 02:40 PM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
