GT/CS side scoop pins or bolts?
Old Feb 27, 2010 | 09:20 PM
mykim72's Avatar
Im looking to see if anyone has the template to put the scoops on and the part # for the pins that you need to drill in...i bought the scoops but they didnt come with the bolts...
Old Feb 27, 2010 | 09:44 PM
ricksGT/CS's Avatar
Talking
I have a friend that had his installed with only 3M two sided tape,,with no problems after two years,,here are some pictures of that car, GT/CS side scoop pins or bolts?-284682-r1-06-5a_007.jpg
GT/CS side scoop pins or bolts?-284682-r1-07-6a_008.jpg
GT/CS side scoop pins or bolts?-284682-r1-00-00a_001.jpg YOU DO NOT NEED TO DRILL HOLES IN YOUR RIDE,,THE SCOOPS WILL LAY INSIDE / UP AGAINST-THE C-PANEL JUST PASS EACH DOOR,
Old Feb 28, 2010 | 06:36 AM
SteelTownStang's Avatar
I never used the push pins on mine either (on my GT)... The 3M alone worked fine. No problems with fitment or concerns of them falling off... Prep well and you'll be good-to-go.
Old Mar 1, 2010 | 12:47 AM
The Ziggys's Avatar
My son and l both have a set of CS/scoops on our stangs too. The first time the body shop just put them on with the 3m tape. l told them l wanted them to use the grommet and pins but they Guaranteed me they would never fall off. They went as far as to say l couldn't even pull them off with my hands if l tried. So my sons first set is on the I-75 some where from our trip from Canada to Kentucky. 20 miles after he lost one l noticed in my side mirror one of mine flopping around . l stopped and pulled it off before l lost it. Next day l pulled the other one off along with my son's other side. l will admit l had to pull pretty good but they did come off. The hardest was getting the 3m tape off the paint. When we got home the body replaced my son's and reinstalled mine with the 3m tape grommets and pins free of charge .
Fords4Ever
2011 - 2014 GT/CS
21
Mar 1, 2021 12:22 PM
FromZto5
Sep 30, 2015 05:28 AM
Stephen Laslo
V6
Sep 18, 2015 07:57 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
