Got into an accident and bent K-Member, need help
I ended up hitting a curb at a decent rate of speed over the weekend.
I knocked off my Classic chin spoiler, bent my drivers side front rim and popped the tire. After inspecting the front suspension my k-member is bent. The wheel is pretty much all the way to the right to keep the car straight.
I have a couple of questions.
Should I get another OEM or aftermarket k-member and why? If aftermarket which one?
How much should I expect to pay to have one installed?
BMR says you can put theirs in with handtools in two hours but that seems a little too good to be true. Thanks in advance for everyone's help!
I knocked off my Classic chin spoiler, bent my drivers side front rim and popped the tire. After inspecting the front suspension my k-member is bent. The wheel is pretty much all the way to the right to keep the car straight.I have a couple of questions.
May as well trade up to a aftermarket K-member. Don't know how easy it is to get a OEM one. Perhaps you could have the car checked out to make sure other parts of the chassis and suspension aren't bent out of spec. before installing whatever K-member you go with. Good luck.
The rest of the suspension looks ok, I had a pro check it out. He thinks just dropping the K-member in will bring the steering back to center. I'm going to order the BMR unit today so I can get the ball rolling. Then put the car in storage until spring and do the body work then. Thanks for the input guys!
Cobiecane
Oct 23, 2015 08:44 AM
