front sway bar links and tie rods
Old Oct 20, 2012 | 05:40 PM
05mu5tang's Avatar
just replaced sway bar links. next week tie rods inner and outer.
Old Oct 20, 2012 | 05:42 PM
How many miles?
Old Oct 20, 2012 | 05:46 PM
05mu5tang's Avatar
100k..
Old Oct 22, 2012 | 03:26 PM
amustangrocks's Avatar
yep, thats when i had to do mine too about 100k. my tie rods looked just like yours. i got the sway bar end links from cj`s. they were a little thinner than oem but they had joints that you can put a end wrench on the back while you tighten the nuts. i also did the frt control arms/ball joints. used the frpp arms. in the last yr they have gone up $150 if i saw it right. everything is going up lately.
Old Oct 24, 2012 | 02:45 PM
05mu5tang's Avatar
yeah... i went with moog sway bar links and tie rods.. they are solid and not hollow.. also have grease fittings... good stuff
Old Oct 25, 2012 | 02:09 PM
JerryG2163's Avatar
My car is getting up there in miles and I may have to get these done eventually. About how much did it cost for parts? Can you give me a reasonable estimate for labor too? It's always good to keep track of these things because they will need to be done in the future at some point
Old Oct 27, 2012 | 02:02 PM
JerryG2163's Avatar
Nobody can comment?
Old Oct 28, 2012 | 08:02 AM
dly's Avatar
dly
Originally Posted by JerryG2163
Nobody can comment?
Here are some prices from Auto Rock.com. Prices to install at a garage are about $100 an hour (figure about 3 or 4 hours) or you could diy for free.
2007 : FORD : MUSTANG : 4.6L V8 SOHC : Suspension : Ball Joint PriceAdd to CartDEEZA Part # FOG639 More Info
Front Lower$26.99
MOOG Part # K500033 More Info Problem Solver
Problem Solver - incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces; Front Lower; GT Model; Shelby GT
$38.79ACDELCO Part # 45D2322 More Info {#19161666}
JOINT,FRT LWR CONT ARM BALL -; LOWER; 2 DR CONVERTIBLE
$39.79RAYBESTOS Part # 5051322 More Info Professional Grade
Front Lower
$44.79
2007 : FORD : MUSTANG : 4.6L V8 SOHC : Suspension : Stabilizer Bar Link PriceAdd to CartDEEZA Part # FOL760 More Info
Rear; Coupe; Shelby GT [Wholesaler Closeout]$6.29DEEZA Part # FOL670 More Info Premium Quality
Rear; Coupe; GT Model
$14.35DEEZA Part # FOL758 More Info
Rear; Convertible; GT Model; GT Base; GT Equipado (Only 17 Remaining)$16.94MOOG Part # K750139 More Info
$18.69MEVOTECH Part # MK80899 More Info {#K80899} Stabilizer Bar Link Kit
Front (Only 6 Remaining)
$21.79DEEZA Part # FOL689 More Info Premium Quality
Front
$22.79MOOG Part # K80899 More Info Problem Solver
$22.89RAYBESTOS Part # 5451704 More Info Professional Grade
Rear
$26.79ACDELCO Part # 45G0106 More Info {#45G0085, 88912234, 88912256}
LINK KIT,FRT STAB SHF -; REPAIR
$28.79RAYBESTOS Part # 5451106 More Info {#5451085} Professional Grade; Sway Bar Link Kit; Contents: (1) Link w/2 Studs; (2) Nuts - Flange Lock M12 x 1.75; (2) Zerks - Grease
Link With Sockets; Front
$28.79ACDELCO Part # 45G20704 More Info {#19240703}
LINK KIT,RR STAB SHF* Stocked in outlying warehouse--shipping delayed up to 5 business days
$29.79LEMFORDER Part # 3109901 Bar/Strut: For suspension rod; Manufacturer Exclusion: Ford Taurus
Front Axle, Left and right; MUSTANG$44.79
Old Oct 28, 2012 | 04:12 PM
JerryG2163's Avatar
Wow above and beyond on the response! Very much appreciated!
dream2015
Aug 31, 2015 03:55 PM
Mackitude
Aug 13, 2015 01:05 PM
killaz05
Jul 24, 2015 08:49 AM
