foose stallion headlights?
Old Oct 4, 2011 | 02:53 PM
mptant913's Avatar
Anyone know where I can get a pair of foose stallion headlights that dose not require a vin number?
http://northamericantuning.com/catal...acturers_id=24
Old Oct 4, 2011 | 10:01 PM
eddieval5's Avatar
Arent they stock gt headlights with the clear lens off?
Old Oct 5, 2011 | 05:48 AM
mptant913's Avatar
The foose bumper os very different and the lens is on the actual light cup.... but what your saying is exactly what I want to do.. remove the lens and place the lens on the actual light..
Old Oct 5, 2011 | 11:25 PM
Planeswalker's Avatar
Knew a guy that had a Foose, front end looks like the old '60s. Never knew the parts were so guarded, good luck.
Old Oct 6, 2011 | 05:17 AM
05YellowGT's Avatar
It's almost like they were Shelby KR parts
Old Oct 6, 2011 | 10:15 AM
TheDarkSide's Avatar
Good luck. I wanted the Foose headlights minus all of the bumper changes and such. I just wanted the light buckets.
Old Oct 7, 2011 | 10:27 PM
eddieval5's Avatar
You can just purchase them. http://northamericantuning.com/catal...iohnfvhi1mc9o6
If I was doing this id try to find the right size to fit the bumper maybe "HELLA" makes some in that size?http://www.classicdesignconcepts.com...t_detail&p=232
Old Oct 8, 2011 | 11:17 AM
mptant913's Avatar
When you ser the description in the first link it says vin number required
Old Oct 9, 2011 | 08:13 AM
The Foose Stallion headlight system was one unit with the front bumper were they not? I don't think they had seperate buckets, just one piece since they had made the new light design.
Old Oct 9, 2011 | 05:20 PM
mptant913's Avatar
Yea your prob right but I wanted to customize it to fit.... problem is I bought painted headlights and they have got condensation now and to be honest I rather remove the lens and put lights with there own lens on the actual circle
Old Oct 10, 2011 | 06:26 AM
05YellowGT's Avatar
CDC did this when our cars first came out and the problem is the gap between the bucket and the facia. It's not noticable when the lens is there , but once you remove the lens it is very noticable ...
Old Oct 10, 2011 | 09:02 AM
Yes it is, which is why the Foose piece is so nice. With the bucket molded into the bumper cover there are no gaps. It would be nice if a company had actually made a set of buckets that were slightly larger and filled in the gap problem.
Old Oct 10, 2011 | 03:00 PM
mptant913's Avatar
Yea I remember those .. exactly what I was thinking but I guess the gap would mess things up.. looks like I am just going to have to take then off and reseal them... very upset about it because they are the best mod I bought and rpi designs said they never had a condensation complaint ...
Old Oct 11, 2011 | 05:31 AM
05YellowGT's Avatar
RPI is where I got mine and mine fogged up too. There was no noticeable gap between the lens and bucket , but I assumed that was the problem and did fix it. I first got rid of the condensation by pulling the bulbs out to make an opening for the moisture to escape. I then put a bright shop lamp in front of the lens about 6" away and let it heat the moisture so it would escape through the bulb hole. It took a few times , but eventually all the moisture was gone. I then put some RTV Silicone around the seal between the lens and bucket and the moisture has never come back ...
Old Oct 11, 2011 | 08:20 AM
mptant913's Avatar
Thank you... looks like I will be following the same process ...
Old Oct 14, 2011 | 08:25 AM
mptant913's Avatar
http://www.americanmuscle.com/mustan...iler-0509.html
Look at the headlights in the show picture... why does CDC tease us.. ! I know I have painted headlights already but **** I want a pair of those
JonsMustang
Mar 5, 2016 05:44 PM
ricky1728
1994-2004 V-8
Sep 28, 2015 10:16 AM
CoyotePremium13
Sep 23, 2015 06:45 PM
50Cal
Sep 17, 2015 06:43 PM
