Floor Jack Recommendations?
Old Apr 11, 2006 | 09:27 AM
Buck_Nekid's Avatar
I purchased a very inexpensive floor jack that met my needs just fine. But after installation of the suspension mods, it doesn't fit under the lowered car. I have to use the stock scissor jack to lift the car a few inches, then I can put the floor jack under there and finish lifting until the floor stands fit. I did it once and that was one time too many.
So I'm hoping for recommendations on a new, quality floor jack that will fit under there. But I don't want to spend a mint, either, and the better jacks aren't cheap.
After searching and reading for about a week, the front-runner is a Summit low-profile:
http://store.summitracing.com/partdetail.a...15&autoview=sku
Any and all suggestions and recommendations are appreciated!
Old Apr 11, 2006 | 09:54 AM
adrenalin's Avatar
why not do what I have to do. Just drive the car up onto some 2x6's and then there is enough room to use your floor jack.
Old Apr 11, 2006 | 11:11 AM
Shea's Avatar
I have to get mine up on 4x4s because of the combination of my chin spoiler, lowering, and my nice jack not being very low, but I just put the car up on a 2x6 (like Adrenalin mentioned) in front of a 4x4 and drive up on them.
Old Apr 11, 2006 | 11:26 AM
lodom's Avatar
You might try WalMart. I've seen a smaller Al jack that might work over there in the past that wasn't terribly expensive.
Old Apr 11, 2006 | 11:51 AM
199's Avatar
199
on my brothers car its really low, so to jack it up he drives over a small brick and then we jack it up, he told me there a "performace" jacks wich might be able to jack his car but they are expensive, this might help http://cgi.ebay.com/ebaymotors/Aluminum-Ra...sspagenameZWDVW
just look for "low profile jack" in ebay
Old Apr 11, 2006 | 01:06 PM
TorchRedBeauty's Avatar
I think the 2x4 or 2x6 idea is probably the easiest. You could also use ramps to get it up a bit first. However, if you still want to get a jack, I just saw a cheaper one at my local Costco. I don't know if all Costcos have the same stuff, but it is all aluminum, low-profile like the Summit one, and is only $100. If you have a Costco membership, you may want to check it out.
-TRB
Old Apr 11, 2006 | 01:25 PM
Helium's Avatar
Sears makes an awesome floor jack. It's the wide style jack with two wheels in back and a roller in front. It has the lowest jack pad I've found (able to fit under the jack point on my lowered GTI), it has the integrated jack handle just like a pro jack, and it's aluminum so it doesn't weigh a ton. Cost more than a WalMart jack, but not near as much as it probably should.
Old Apr 11, 2006 | 01:27 PM
Zig-Zag's Avatar
<div class='quotetop'>QUOTE(TorchRedBeauty @ April 11, 2006, 12:09 PM) Quoted post</div><div class='quotemain'>
-TRB
[/b][/quote]
+1 on both using a 2x6, and the Costco jack. I used the former, until I purchased the latter. The jack is even low enough to allow me to use the jacking plates I had fab'd.
Old Apr 11, 2006 | 01:43 PM
TDS's Avatar
TDS
Super Moderator
TMS Staff
Here locally in Bama, both Sams wholesale and Costco have nice aluminum "race" jacks.
Race jack copies if you will. Both stores have them at approx. $100 - $125 a piece.
They look to be the same manufacture, just different anodized colors.
Have a low front solid roller to slide under lowered suspension, most raise to 36" - 48" heights.
Sears has a similar one in their tool catalog, however they want more for it.
TDS [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old Apr 11, 2006 | 06:03 PM
Kenichi Mifune's Avatar
<div class='quotetop'>QUOTE(TDS @ April 11, 2006, 1:46 PM) Quoted post</div><div class='quotemain'>...most raise to 36" - 48" heights.[/b][/quote]lol- Come on!
I use a 2 ton, aluminum. Works great.
Old Apr 11, 2006 | 11:28 PM
Gearhead's Avatar
Just 1½” further up off the ground will allow you to get under your car just like it was some garden-variety piece of Detroit Iron. A quick way to make a set of four Mini-ramps is to get an eight foot 2”x12”, cut it in half, then bevel-cut the halves into two-foot sections, each with a single 45-degree cut. Nail 2”x6”s as a stopper on the end of each Mini-ramp, and you’re done.
Feb 10, 2017 07:12 PM
wallace
Mar 29, 2016 10:09 AM
GeoWett
Sep 30, 2015 06:40 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
