Engine "stumbled" ?
Engine "stumbled" ?
I have been driving this car for almost a year with no problems. I routinely excelerate " briskly "
Today, I pulled over to put the top down, went to pull out, dumped the clutch, stomped the gas and ...... it "stumbled" ( for lack of a better word ). I have driven a stick for 24 years and never experienced anything like it. It happened a second time on this trip also.
Could bad gas cause it? any other possibilities?
![Burnout](https://themustangsource.com/forums/images/smilies/burnout.gif)
Were you on a long drive prior?
Was it the bucking or hesitation?
'cause that's what it sounds like
If so check the TSB on it.... its a fuel pump issue after long cruises
I never followed that thread .... time to research .... thanks.
Edit - read several of the other threads, once you know the keyword ( bucking or hesitation) there is tons of info. It sounds like this is the problem and now that I think I know what happened, I might be able to reproduce it. Thanks again - guess this is a good time to have the brake fluid mess fixed also.
No problem man..
I have the exact same issue...
Its after a 1:30 - 2:00 hour drive... upon either accelerating, downshifting etc....
Seems like the replacement fuel pump fixes the issue.
There is a TSB on this. The material on the pickup tube for the fuel pump collapses causing a momentary "stumble." Mine does it too occassionally, just haven't had time to take it in.
Evil_Capri
9/11/15 08:39 AM
