Engine Jewelry
Old Apr 15, 2010 | 07:43 AM
69Mach1-409's Avatar
Not sure about the idle AF's, but the other two look correct to me. Under boost I believe you should be in the 11's with your AF.
*Question: What is the what is the metal box on your passenger side strut tower? ..it has two wires coming out of it.
Old Apr 15, 2010 | 08:11 AM
Dixie_Flatline's Avatar
Now that's beautiful! Nice job.
Old Apr 15, 2010 | 09:34 AM
2007CalSpec's Avatar
Originally Posted by 05YellowGT
I have interceptor scan gauges and my fuel pressure is a delta function , so it fluctuates around 39 psi at idle since I have 39# injectors. Your gauge probably reads true pressure and depending on what size injectors you have I'm not sure what it should read. The boost reads about -10.8 to -11.0 at idle and at WOT 7.5 to 8.0 psi which is correct for my pulley size. I don't know for sure but -20 psi seems high to me , maybe someone else will know for sure ...
Thanks for the info. I believe my injectors are 38#.
Originally Posted by crescent_wrench
Sick. Congratulations! Love those gauges BTW.
Thanks!
That metal box is the flux capacitor. It ties in with the Whipple so I can travel through time. J/K! It's actually the ballast for my HIDs.
Thanks!
Old Apr 15, 2010 | 09:35 AM
HAHAHA!
Old Apr 16, 2010 | 05:03 AM
Andretti1's Avatar
You've really made some awesome choices if I do say so myself (since everything I've seen on this is what I want to do as well).
Grats on getting it up and running. That polished charger just looks incredible. Grats.
Andretti
Old Apr 16, 2010 | 08:39 PM
Andretti
Thanks! Much appreciated!
Road_Runner
Sep 2, 2024 04:46 PM
trackpack13gt
Oct 2, 2015 08:20 PM
Evil_Capri
Sep 11, 2015 08:39 AM
