Engine cover getting worn
Old Oct 8, 2006 | 10:56 AM
classj's Avatar
I have the late 06 liner and it is rubbing. I think the back of the cover can be lowered by doing the mod where you lift the cover, remove the fuel rail studs, and use those to hold the cover down.
Old Oct 8, 2006 | 12:46 PM
exgto's Avatar
Why not just remove the cover?
Old Oct 8, 2006 | 01:04 PM
mustangjack's Avatar
You could just cut a hole in the hood so it doesn't touch.
Old Oct 8, 2006 | 06:51 PM
Boltzman's Avatar
The reason we bought it is cuz it looks kick **** Mine is rubbing toward the front so lowering the back part wouldnt matter
Old Oct 8, 2006 | 09:46 PM
StangNut's Avatar
Maybe that's why they decided not to use it when the '05 came out.
Old Oct 9, 2006 | 06:13 AM
05RedGT's Avatar
+1 My cover is wearing as well - looks like the hood liner sags in the back area as there is no fastener in the back to hold it tight to the hood. I will try the cloth tonight.
Old Oct 9, 2006 | 08:58 AM
Originally Posted by PonyLover
Yep.
Just went out and took one.
Sorry I was incorrect about the cut out.
The liner in the pic above (my first port) was orig from factory when I got it.
This one they said was from Ford as I told them no after market.
http://forums.bradbarnett.net/attach...3&d=1160174479
I like mine better I am going to use some double sided tape to hold the liner up in place in the back there where its sagging
Old Oct 9, 2006 | 06:45 PM
Boltzman's Avatar
The cloth stays put. I'm on 5th day now and it does not move when driving
Old Oct 9, 2006 | 08:11 PM
aircare84's Avatar
Washcloth idea working here too.
If you feel the liner, there is a 'stiffner' moulded on the underside of the hood also,kinda presses against the Ford intake cover,not sure if there is an easy fix, like duct tape or anything.I'll probably keep the cloth there,hopefully this will keep it from wearing anymore.
CiniZter
25
Apr 28, 2016 05:41 PM
Glenn
73
Apr 26, 2016 12:22 PM
mustangsally_
Sep 18, 2015 05:35 AM
SterlingStunner
Sep 16, 2015 12:30 PM
Evil_Capri
Sep 11, 2015 08:39 AM
