electical ? about control panel around radio
I recently installed an kenwwod radio in my 05 gt.that i got from crutchfield.which was great.great instructions and great tech line.Anyway.Radio is in and works.Now nothing in the control panel around radio works.ac,defroster, traction control.........Any suggestions on what to look for?
Sounds like the connector on the lower right behind the A/C selector **** isn't seated all the way. This happened when we installed my radio once. Just recheck how well it's seated. It should fix it right up.
-danny
-danny
the drivers side with the intensity setting clicks in place & it could look to go in more than one way but only one way , and the passenger side has the little plastic bar tab that jumps back into lock position when in place right , I`ve had mine out at least 6 times for something 10 job council front face or you could just take out the council trim & the side kick plates and then just reach in, I`ll look see if I had a PDF file on it !
no sorry I didn`t have it just for the car`s instruction manual. but I have seen it some where mabe in the modification section re installing AVIC - Pioneer stuff .
