Convertible Top Help
Old May 19, 2015 | 03:26 PM
Randle's Avatar
I'm new to this forum and I need some unexpected help, I have a 07 convertible
that the wife drives, when she came in this evening the top wouldn't go up. I can hear some clicking noise under the top when she pushes the switch, but it don't move. Is there any way to manually raise the top till I can try to find out what is wrong with it.
Thanks for any help.
Randle
Old May 19, 2015 | 07:26 PM
mrkabc's Avatar
Randle
Hi Randle:
STOP! Don't try to manually raise the top, you can bend the frame if you try.
Check your fuses? I'd start there first.
You might want to check for obstructions to the motor? The motor is located behind the passenger side rear interior panel. You'll need to pull the top piece that the front passenger seat belt passes through, then you can clearly see the motor assembly. There are no screws, just retainer clips.
What do you see for the above two points?
Old May 19, 2015 | 08:31 PM
Randle's Avatar
The manual shows two fuses, and they are both good. You can hear the relays clicking when you push the switch.
I removed the cover you were talking about and I can see the cylinder, but not the motor. Nothing looks out of place or binding on either cylinder.
Old May 19, 2015 | 08:44 PM
houtex's Avatar
The procedures to diagnose are here:
Convertible Top Diagnosis.
Follow those. You'll figure it out with that.
If you cannot do these, for whatever reason, then you should take it to the dealer who has the proper tools and training/knowhow to figure it out for you.
Old May 20, 2015 | 06:04 AM
Randle's Avatar
Thanks for the replies, and for the procedures I will try to check it out this morning.
Old May 24, 2015 | 12:06 PM
Randle's Avatar
Thanks for the help guys: Come to find out the switch was bad.
Old May 24, 2015 | 05:28 PM
mrkabc's Avatar
Wow, I didn't see that one coming!!
<sheepish>
Talk about overthinking the problem!! Hahahahah!
Thanks for letting us know!
Old May 24, 2015 | 08:13 PM
Randle's Avatar
<sheepish>
I've always heard you overlook the simple things looking for the complicated.
That is sure what I done.
May 3, 2026 05:42 AM
Autotooner
Nov 24, 2017 12:42 PM
yabutt
Oct 23, 2015 01:05 PM
mlcinema
Oct 7, 2015 10:05 AM
