Code Reader wont connect
Old Jul 24, 2015 | 06:04 PM
cloyd65's Avatar
I have a 2005 Mustang GT that Ive owned for about a year now. Two days ago I noticed the CEL had came on and I decided to run a code reader to see what the issue was and the code reader keeps giving me an error and that its not linking to my car. Anything that could lead to the issue would help greatly! Thanks.
Old Jul 25, 2015 | 06:01 PM
kd4gij's Avatar
First, What code reader do you have, and have you used it on this car before?
Old Jul 25, 2015 | 06:31 PM
go to autozone and have them hook you up.
Old Jul 28, 2015 | 11:22 AM
cloyd65's Avatar
I have a OBD II reader, not sure which brand and no I have not used it on this car before. It works on all of my other cars but not this one.
Old Jul 28, 2015 | 02:43 PM
kd4gij's Avatar
Look in your owners manuel fo a fuse for the OBDII port. I havent looked but on my F150 the fuse for the power ports also power the obd port.
Is your reader a bluetooth that works with a phone or tablet?
Old Jul 28, 2015 | 06:37 PM
ford4v429's Avatar
legacy Tms Member
is it a production scan tool, or a ebay bluetooth device?
I bought several bluetooth devices before I got one that worked(PLX)with my 'torque' track recorder app. on my mustang, but some worked fine on other cars... the PLX 'Kiwi' unit works on all of them (but its corded, to a module with the bluetooth- and the cord hits your leg...I got a right angle adapter and stuffed the whole thing under the dash)
I have a actron scanner I bought back in 05 or so from Autozone, it has worked on every vehicle we have.
a lot of the ebay stuff is pretty iffy. I did find one cheap one that seems to work fine, a lot cheaper than the kiwi, bought several so have one in each car- for no good reason... I'll try and find a link to the cheap ones that worked
Old Jul 28, 2015 | 06:43 PM
kd4gij's Avatar
I have read that alot of the cheap BT units won't work with ford. That is why I asked.
Old Jul 28, 2015 | 07:49 PM
ford4v429's Avatar
legacy Tms Member
these (and the PLX one) work on all our cars, all the other bluetooth adapters I tried wouldnt link up to the mustang...
the 'torque' app is really cool-with the 'track recorder' part, you can superimpose any gages you want + any phone sensors you want, onto the video being recorded- if you can mount your phone up
Old Jul 29, 2015 | 10:51 PM
Lime GT's Avatar
Check Fuse #8-10amp smart junction box.
Old Jul 30, 2015 | 08:48 AM
Lake_Vert's Avatar
I've been using BAFX bluetooth obdii done and dash commander. I bought an extension cable for the odbii because the BAFX stuck out too far to work the clutch comfortably.
I bought dash commander and have enjoyed building my own displays for the past few weeks.
As suggested, take the car to autozone, advance, ... and have them read your code. If they can, your device is at fault. If they can't, then it's with the car.
May 3, 2026 05:42 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
haitham
Sep 8, 2015 12:52 PM
