check engine light question
well on the way to work this morning the check engine light came on.......i shut her down restarted it did not go away....checked the gas cap and restarted it did not go away....when i go home i used my sct to check the trouble code or code i came up with P0456 and if i am correct this car has EEC V........IS THAT CORRECT...i did a search for trouble codes for eec v and came up with this......... P0456 Very Small Leak Detected in Evaporative Emission Control System ...now the fun begins bringing it in to the dealer tomorrow first thing in the morning... i will let you know how it turns out.......
I had the check engine light come on in my car a total of three times...and each time the car was running fine.
The first time the dealer checked the car and reset the computer...second time the light shut off on its own.
The last time the light came on a few days after I had the car in for service and had the TSB done on the front struts...I took the car back to the dealer and when they checked the car they found a valve in the emission system sticking open, the reset the computer and ordered the part...and when it came in I went back to the dealer and the replaced the part in about 45 minutes.
Check engine light came on my stang, took it to dealer, ran a computer test on it, said it was leaky vapor(?) possibly coming from new tank......told me to not use the locked gas cap, so now back to using the original cap. They turned off the check engine light and said to see if that helps. So far, so good.
well the dealer was closed today for the holiday weekend.....next week i am going to bring it in........i have had my locking gas cap a while so i doubt that it`s the problem....i had the tank changed awhile ago as well..so maybe something has come loose....will see....
ssjbuu
8/28/15 08:55 AM
