changing coolant?
With that said, I believe it's no different than any 4.6 currently from Ford.
I added some water wetter to my coolant mix and now I'm getting some unwanted residue in the coolant tank. I'm not sure if there is a compatibility issue with water wetter and the motocraft premium gold coolant, but I don't want to take any chances. I used water wetter in my 03 stang and never had a problem with this. I just want to flush it out and go back to the factory fill.
I think the cooling systems in todays cars are very goog at venting trapped air. So I would not think draining and refilling would be that difficult
Given you may have contaminated the system though, you might be better off asking you Ford dealer to flush and refill for you.
Just a thought.
If you have the Gold Premium Coolant (comes with GT)...it is good for 4 years or 100K miles...you can count on it...change it at 3 years if you want to.
Lots of cars have the extended life coolant now (GM started that back in the mid-90's with Dex-Cool and the Europeans have been doing it a lot longer). Dex-Cool is good for 5 years and/or 150K miles...I usually have mine changed out at 4 years.
If you have the standard green coolant...then you should change it out every 2 years and/or 36K miles...
P.S. your dealer has the Premium Gold Coolant for about $15/gallon...keep it on hand if you should have to refill the resevoir (i.e. keep it at the prescribed level when cold)...be sure to mix it 50/50 with distilled water (not tap water)...
unnoticedtrails
7/17/17 11:10 AM
DerekShiekhi
9/30/15 06:59 AM
